Aqara FP300 support implemented in Aqara app
It would be very nice if the Aqara app supports The Aqara FP300 presense utility with the Zigbee protocol. With Matter it is working in Homey but poor possibilities with cards. Thanks
You should post device requests in the matching app topic. You can find it on the app page at the homey.app store.
And with a little forum search: no need to request it anymore for zigbee support:
I’m experiencing a strange issue with my Aqara FP300 (lumi.sensor_occupy.agl8) connected directly to Homey Pro using the official Aqara app (v1.16.3).
Environment
  • Homey Pro
  • Aqara App v1.16.3
  • Device: Aqara FP300
  • Model: lumi.sensor_occupy.agl8
  • Zigbee route: 0 → 7 → 8
  • Firmware: Up-to-date (confirmed through Aqara Hub E1)
What I tested
To rule out a firmware or hardware problem, I:
  1. Removed the FP300 from Homey.
  2. Factory reset the device.
  3. Added it to an Aqara Hub E1.
  4. Updated the firmware (already on the latest version).
  5. Tested the sensor in Aqara Home.
Results in Aqara Home
The FP300 behaves exactly as expected:
  • Presence becomes active when entering the room.
  • Presence turns off shortly after leaving the room.
  • Motion and presence detection are working correctly.
Results in Homey
After removing the sensor from Aqara and pairing it again directly to Homey:
  • alarm_motion remains true
  • alarm_presence remains true
  • Lux, temperature and humidity continue to update normally
  • The device remains online
  • RX counters continue increasing
  • Last Seen updates continuously
Example
I left the room for approximately 25 minutes.
During that period:
  • alarm_motion stayed true
  • alarm_presence stayed true
Even though the same sensor reports absence correctly in Aqara Home.
Developer Tools
  • Current capabilities:
  • alarm_motion true
  • alarm_presence true
  • measure_temperature 26.9
  • measure_humidity 57.8
  • measure_luminance 134.99
  • measure_battery 75
Additional observations:
  • Last Seen: ~1 minute
  • RX: 182+
  • TX Error: 12
RX continues increasing, which suggests Homey is still receiving messages from the device.
Why I think this is a Homey integration issue
  • Firmware is up-to-date.
  • The FP300 behaves correctly in Aqara Home.
  • Homey continues receiving updates (lux, temperature, humidity, RX counter).
  • Only motion and presence appear to get stuck.
Has anyone else seen this behaviour with the FP300 (lumi.sensor_occupy.agl8)?
It should be fixed with app v1.16.3
Apparently it is not.
Please report your findings to the appropriate Aqara app topic, else the developer is unaware of your post:
Hi Peter,
Thanks for your reply. what is the appropriate aqara app topic for this? I checked but ended up here.
  • never mind found it - Thanks!
Hello, you used a wrong emailadres for your question. Resend it to the right person. Succes
