Issues with Aqara FP300
I have had the same problem, so I started replacing my FP300’s with the Lafaer Presence sensor. They are not as nice looking as the FP300s, but once you get them paired, they work very well, plus they use AA batteries.
Adding to this thread since it’s the more active FP300 discussion, and I want to consolidate what’s known about the underlying cause.
There’s a parallel thread (Firmware problem with Aqara - Presence Multi-Sensor FP300, 155180) where I and others have been tracking the same issue. Short version: after Aqara firmware 0.0.0_6542 (released May 26 2026), the FP300 stopped emitting autonomous Zigbee attribute reports for manuSpecificLumi unless the platform driver explicitly configures reporting. This causes the 24-hour dropout and stuck-state symptoms on Zigbee.
The diagnosis (andreas_roedl, SmartThings driver maintainer, on the Aqara forum thread 299625 post #10): platforms must bind manuSpecificLumi (cluster 0xFCC0, manufacturer code 0x115F) and configure reporting for 0x0142 (presence) and 0x014D (PIR motion). Type Uint8, Min:0/Max:300/RepChange:1.
Status across platforms:
- SmartThings Edge driver: fixed (andreas_roedl)
- Zigbee2MQTT: fix released via PR #12383 (drauziooppenheimer, merged)
- ZHA: pending quirk update
- Homey Aqara app: no update yet
Direct confirmation on the Homey side comes from @Viger_Ostensen’s June 7 post in this thread — he captured the Zigbee interview log for his FP300 showing every attribute has reportingConfiguration: NOT_FOUND, and the bindings section only contains time and ota (no manuSpecificLumi binding). That is exactly the missing configuration andreas_roedl identified.
@TedTolboom — the reference implementations are public. Is porting the same fix to the Homey Aqara app something you can look at? Happy to test a beta if that helps.
My own situation for context: 4 FP300s on Homey Pro 2026, all on firmware 6542. Even after replacing all IKEA TRETAKT plugs with ThirdReality Gen 3s (which addressed Aqara/IKEA routing incompatibility for me), 2 units still drop to a no-detection state every ~24 hours. “Try to Repair” resolves it temporarily by re-running the interview — which is consistent with the missing reporting config theory.
The Lafaer Presence sensor does work great. Have you seen the new one. The LWR02 is a better looking sensor with both PIR and mmWave. Currently on backorder.
Have you actually used the LWR02? As it seems to become available not before August this year?
I have not used the new one. The one I was talking about working great is the LWR01. I will order the new one when it becomes available later next month. Hopefully it works even better than the first one.
I agree. My FP300’s seem to crap out about one per month so I will get a few too
Curious what your experience will be. Looks like a very nice device based on their product page :grinning_face:.
If it performs like the LWR01, then it should be good. They are just so ugly. My wife hates them compared to the FP300’s
Nice
Think I’ll be putting my FP300 on sale then and grabbing these next month
Closing the loop on this one. Placed the same reply on thread "Firmware problem with Aqara - Presence Multi-Sensor FP300" as well.
The Homey Aqara app was updated about a week ago with what appears to be the fix (explicit manuSpecificLumi binding + reporting configuration for the manufacturer-specific presence and PIR attributes) that andreas_roedl documented on the Aqara forum and that SmartThings and Zigbee2MQTT had already implemented.
One week in on my 4 FP300s: only a single hang across the entire fleet, on the lavatory unit around day 4. Otherwise stable. That’s a dramatic improvement from the every-24-hour dropout pattern we were all fighting.
A few thank-yous:
@TedTolboom for shipping the fix.
@Peter_Kawa for the IKEA routing hypothesis and the Z2M/Home Assistant reference docs — the mesh fix (removing all IKEA TRETAKTs and replacing with ThirdReality Gen 3s) was a real improvement even before the app update.
@Jason_Edwards, @Trond_Nordfjaern, and everyone else who added data points across platforms — the cross-platform evidence is what made the diagnosis convincing.
And credit to Athom support (Bas) for escalating internally when the community-facing side went quiet.
Leaving this here in case anyone lands on the thread searching for the FP300 24-hour dropout issue — the fix is in the Homey Aqara app, update it and give it a week.
Switched my FP300 over to zigbee after the app upgrade and it has been running perfectly for several days now. Big thanks to all the guys who contributed to getting this fixed! :blush:
The app upgrade won’t have anything to do with how the device performs over Thread, only Zigbee.
My bad - I ment switched from matter back to zigbee. Had it in matter mode while the issue was under investigation
Ah, Did exactly the same. Switched to zigbee and now it performs very well. Also noticed extra option in zigbee called presence, in thread I only had movement. So to me it seems it worked in thread only with pir and not with mmwave. This was also noticable in thread because it’s behavior was the same as the PIR sensor it replaced.
There is a firmware update to this device for Thread in the Aqara app, firmware version 1.1.3.8
However, this firmware version does not appear to be present in Homey or Home Assistant
It would appear that Aqara is not putting out firmware updates of it’s products to the Matter OTA standard
Does this mean they are breaking certification requirements?
I don’t think so. Why would a brand need to give away their firmware files? Just because the brand doesn’t offer a server to download OTAs doesn’t mean that they’re breaking the Matter standard, the device can still be integrated in multiple ecosystems (Smartthings, Homey, Hubitat, etc.)
I still have some issues. After 1 month, my zigbee Aqara FP300 just froze on presence and motion. Not sure what I could have done differently but still annoying. Needed to restart it but would have wished for something more stable to be honest..
Well Aqara just released the FP400, so you can safely assume there will be no more firmware updates for the FP300. It’s just how they operate.
Well, they’re not the only company that does this. You also often see this on Smart TV’s, those never get updates when there’s a new model
I understood that the FP400 is the successor of the FP2. Both require permanent power via USB. The FP300 is battery powered. I don’t think the FP300 is discontinued.
