iSmartGate app with more than one device
I’m using the iSmartGate app and its working fine. My problem is that the app only allows me to connect to one iSmartGate device in the settings and I have two devices? Is there anyway to solve this? Can I for example install a second instance of the app that I configure with my second IsmartGate device?
Thanks for any help in this matter.
Hi Philip,
When you’re familiar with CLI installs (find howto here), you can install a second iSG app, but only after you change the app ID a bit in the
.homeycompose/app.json file;
Change line 1 into, for example:
"id": "com.gogogate.ismartgatephilip"
and change line 11 into, for example
"en": "ismartgatephilip"
This should make adding your 2nd iSG device possible
App download:
https://github.com/iver56/homey-ismartgate/archive/refs/heads/main.zip
@Peter_Kawa Thank you so much for taking your time to help me. Highly appriciated. I had a good start. did everything according to instructions. But when I enter “homey app install” I get this:
:heavy_multiplication_x: Command failed: npm ls --parseable --all --only=prod
npm WARN config only Use --omit=dev to omit dev dependencies from the install.
npm ERR! code ELSPROBLEMS
npm ERR! missing: fast-xml-parser@^4.0.7, required by com.gogogate.ismartgate@1.0.0
npm ERR! missing: node-fetch@^2.6.7, required by com.gogogate.ismartgate@1.0.0
npm ERR! missing: uuid@^8.3.2, required by com.gogogate.ismartgate@1.0.0
npm ERR! A complete log of this run can be found in: /var/root/.npm/_logs/2023-11-29T07_43_03_896Z-debug-0.log
:heavy_multiplication_x: Error: This error may be fixed by running npm install in your app.
at /usr/local/lib/node_modules/homey/lib/App.js:874:15
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async App._copyAppProductionDependencies (/usr/local/lib/node_modules/homey/lib/App.js:871:26)
at async Promise.all (index 1)
at async App.preprocess (/usr/local/lib/node_modules/homey/lib/App.js:826:5)
at async App.install (/usr/local/lib/node_modules/homey/lib/App.js:767:7)
at async exports.handler (/usr/local/lib/node_modules/homey/bin/cmds/app/install.js:25:5)
Could you please help me with what to do?
Best regards,
Philip
YW, Philip!
The possible fixes / solutions are returned, but you have to read the error message carefully
(By ‘install in your app’ is meant:
when the path is the app folder, run
npm install
This way ‘npm’ gets installed into the app code)
There can be several error messages after each command, with a proposed fix.
In the end, the app should install error free @ Homey
Thank you @Peter_Kawa I got it to work now :+1:
Hi Peter :slight_smile:
I hope this message finds you well…
I have the same problem as Philip : need for a 2nd instance of ISG App.
  1. I followed CLI install protocol : I downloaded Node.js v.22.x (higher than my Homey’s v.18.x) and installed it on my computer.
  2. I downloaded the App Zip file in your post to Philip, unzipped it in my Downloads directory
  3. Setup Nodejs in Terminal (cmd prompt) : npm install -g homey and logged in with success through the webpage that had opened
  4. I navigated in Cmd prompt to my Downloads rep :
    cd /Users/DF/Downloads/homey-ismartgate-main
    and chose when prompted my Homey device as Active Homey
  5. I changed (and saved the file ) the App Name on lines 1 & 11 for
    “id”: “com.gogogate.ismartgateGREG”,
    “en”: “ismartgateGREG”
  6. Still in Cmd I ran : npm install and addressed 1 moderate severity vulnerability (out of 12 packages) using npm audit fix. I ran again npm install and 0 vuln. where found.
By now I should see IsmartgateGREG as a new App on my Homey, right, or did I miss something ?
Thank you for your wisdom & help !
GREG
Hi Gregory,
I happened to ‘stumble upon’ your post.
Pro 2023: you should run homey app install --remote next.
Pro 2016-2019: same command without --remote
Next, you’d see a second iSmartGate app instance
Hi Peter,
and thanks :wink:
did not work as planned unfortunately…
here are screenshots to better understands !
Tx
Greg
YW!
Sorry, but my knowledge ends here, Gregory. What I would do next in this case:
try to install or run an other app this way, to see if the customised iSmartGate code is the issue, or if there’s something going wrong with the CLI procedure.
I had never thought I would see you defeated by the machine ! :wink:
would you by any chance know someone who could help me please ?
Tx again Peter !
:rofl: yes, you got me silenced hehehe.
I’d ask in the CLI topic if I were you!
