In that case, nothing happens. You have to close the app and restart it before anything responds. After that, the dashboard/device overview will reappear as normal.
When I click “More” in the app and then select Homey Pro under my name, this screen looks the same responds. So I assume a bug or regression here.
It doesn’t make any sense for this menu to appear when you open the app if you only have one Homey. The fact that it doesn’t respond suggests there’s a bug.
I submitted it at the end of March and it was confirmed and ticket closed, but there hasn’t been a fix since then :(. That’s why I was hoping for more information.
I’d also be interested to know whether this affects several others as well. At least the people I recommended Homey to, and whom I asked about it, also experience this from time to time. For me, it has recently been happening almost daily.
Important features (like the target_power feature for apps) get backported to older models though.
The mobile app changelog is also there.
The current test version (10.1) has a line “Various fixes: Improved reconnect behavior and notifications, plus fixes across Dashboards, search, and device tiles.” But I already was on 10.1 and that didn’t fix it.
I received 13.4 on the Pro this morning… lets see if it did anything.
In the meantime… lets check some things. I’m kind of low-key expecting that the app/system is timing out somewhere because of the amount of the devices I have loaded. I’m currently at 69 devices, 8 of them virtual. Also 7 devices that do ‘something’ with the data on the Energy tab.
When opening the Energy tab (in particular, but also when just opening the Home tab), I often notice many of the values/elements are blinking/flickering, like they’re rapidly trying to catch up and/or process old values until they settle on the most recent values. Sometimes the app even hangs during this process and Android throws an “App is not responding” error.
Do you recognize any of this? Do you also have a lot of devices active? Maybe if we can find some correlation we can help find some causation.
New experience, never had this message before. No connection lost.
Overall 49 devices, thereof 8 virtual. I haven’t seen anything flickering or app not responding errors. Only constant alarm messages from Fibaro doorsensor 2.
This is usual (but not normal):
The user authentication expires after two weeks, and if so, Homey needs to check your account online @ Athom Cloud.
Somehow this doesn’t work well sometimes.
I get to see this screen sometimes since 2020 with my Pro 2019 and Pro 2026.
I received the following feedback from Athom Support:
The Linux kernel logs show repeated Wi-Fi driver packet corruptions, alongside failed local network ping sweeps. This network instability causes the app’s WebSocket connection to drop with, triggering the app to constantly re-clean context and switch to reconnecting mode.
On the Homey Pro (Early 2019) model, RX packet corruptions are a classic symptom of a failing stock 5V USB power adapter. Voltage instability under load causes the internal Wi-Fi module to drop packets and reset connection sessions.
I have a Fritz!Box 5690 Pro—which is a recent model—and, just to rule out any issues with the power supply, I’ve connected a new 5V 3A power adapter to the Homey Pro.
