Is it possible to turnon/turnoff device in Homey Pro 2023 using curl requests?
I’d like to be turn off / turn on devices in homey using curl from a linux box.
Can someone point me in the right direction?
Thank you.
Take a look at the logic When-flow card for webhooks. There’s also a short description there how it works.
It works when you execute
curl url
When you only use or want to use local webhooks, use this:
curl http://my_homey_ip/webhook?event=my_event&tag=my_tag
(Otherwise follow the hint by CaptainVoni (hover the (i) at the trigger card below))
This flow triggers:
As a ‘device_y on’ and ’ device_y off’ example:
On:
curl http://my_homey_ip/webhook?event=device_y&tag=turn_on
Off:
curl http://my_homey_ip/webhook?event=device_y&tag=turn_off
But this will turn it off as well, while the tag doesn’t match ’ turn_on’…:
Flow:
Screenshot from 2024-03-17 12-32-49
