Hi, I cannot find any information on how to delete a created mood or editing an existing mood. if you have created a mood, you can never get rid of it??
managed to find it in the respecive zone after I got a tip. it was from the home tab, I could not figure it out.
Hello, playing around with moods a little bit and I am wondering if it is possible to add custom default moods that I can choose when creating a new mood.
What I mean with that is:
For example I can select the mood “Focus” to base my mood on that configuration. If I come up now with a combination of color, color temp and brightness I would like to use across all rooms as a default I need to manually set the config and then save a custom mood. It would be much more comfortable if I could save this configuration.
Any ideas?
hi,
is it true that it is only possible to create new moods in the moble App not in the browser App? I don’t see under devices the option +new mood
thx
regards
Ulf
correct:
So for how far is this from the openingspost true? quote “you can create flows […] in WebApp” . I can not find a way to incorporate my moods in a flow (standard or advanced) in the webapp . I can however with some searching find a way to create a flow from out of the edit page of a mood in the mobile app. Is this the only way. It is quite hidden and doesn’t follow normal flow creation ‘flow’ .
The same way applies to flow cards for “app-less” Matter/zigbee/z-wave devices.
Many seem to “skip” the search field somehow:
Entering moods as phrase should show you the same cards
