I am running an IndeVolt Cluster consisting of 2 towers. Each tower has a capacity of 10 kWh and an inverter of 2400 W. Each tower is connected to a different phase of my electricity grid connection. (3x25A). I have also a Homey Energy dongle running which is able to show me the usage per phase. I want to make a flow which should reduce the grid intake when one of the phases has a usage over 90%. I found that the indevolt app within Homey sees my cluster as only one tower, not as a cluster. Which means I cannot Control one of the towers if the usage on that phase becomes too high. I can only set the whole cluster down on AC Intake from the grid between 100 and 2400W. Vice versa, after the usage of a phase is becoming less than -say- 50% I can set the entire cluster via Homey up to 2400W AC input from the electricity grid, but not up to 4800.
Is there anyone who has fixed this problem? Controlling an IndeVolt system operating in a cluster and controlling the master and slave tower separately through the Homey app?
Kind regards, Theo
