Ikea Bilresa with scroll wheel
Hi!
Playing around with Bilresa with a scroll wheel and curtains right, middle and left. (ie Rullgardin Hö, Mitt and Vä)
Got the two button ones as well and there a button click up/down moves it 10% in either direction with a similar flow.
This isn’t working for the scroll wheel..
I’ve obviously made some sort of mistake or the scroll wheel isn’t working as I expect it to. :slight_smile:
Any pointers are appreciated!
Are you sure it accepts decimals, since the last one if it’s over .91 sets it to 100%. have you tried using 100% for everything, and also testing smaller sectioins of the code to see what works instead of starting with a full flow and not testing parts of it? make smaller test flows to see what works then adapt that into the full flow.
