I would like to trigger an event on my Homey with IFTTT.
To do that, I send an HTTP request with Webhooks (IFTTT).
Then, on Homey, I created a flow
but it didn’t work…
Do you know what I did wrong?
Thank you in advance for your help.
Chris
Try working in steps, so remove the AND card to see if the action card gets triggered at all. If not, try opening the URL from a regular browser to see if that works (in which case the issue might be with IFTTT).
In the THEN column, you can create a notification and use the Tag token to see what its value is.
Thank you for your answer.
Well, it seems that it works. I am sorry, I should have checked a little bit longer before posting a message.
