Hi all,
I have a E-thermostat witch works with homey thru the homey ICY app.
I want to make a warning when somebody leafs the door open while the thermostaat is in comfortstand.
However when i make a flow and do a test i looks like that homey is not getting a response back. Is this a one way communication?? Options?
gr,
Frans
Little update, found out that the connection between ICY thermostat and Homey wasn’t working.
Next fault i am getting now when i run the flow in the “and” colum is “missing listeners” does this mean one way communication only?
problem solved , connection was lossed . issue may be closed
