It would be great to have the app have the white (matter) switches added to them. Is there a timeline at all on bringing the beta app to add there other switches besides the blue?
@Kevin_Armstrong did you ever get the Inovelli white working?
I have an red (without presence sensor) and it barely works with the app. I haven’t seen the app author comment on this thread at all.
Not very well and i checked with Homey and Innovelli support. It cab do on/off but thats about it. No double tap, etc.
I tried home assistant too and it wasnt great there either … mich prefer my Zooz to be honest
Connecting the switch this way, do you have the option to put the switch in “smart bulb” mode?
@Comlicenca There is an inovelli driver now that has support for all the parameters of the device. You can use the Advanced Config for the device to set the parameters (all of them), including smart bulb mode.
The driver has flow cards for all the button push options.
I have a few inovelli switches now working perfectly within Homey. For instance, I have a Blue Fan switch that I have disabled local control and changed the single press to turn on and off an LED light strip while having double press turn on and off the fan load that is attached to the switch.
I set all of that up in Homey using the new driver.
I highly recommend the Inovelli switches and Homey.
@Greg_Veres That is awesome to here! I’m also going to be getting a fan switch for my bathroom fan. Is the driver something that is installed directly from inovelli or does it need to be sideloaded somehow?
@Comlicenca Sorry, I didn’t see your reply until just now.
The driver is the Inovelli app on the Homey app store. Just search for inovelli.
The driver that is there now supports
- LZW30 (zwave on / off switch)
- LZW31 (zwave dimmer - gen 2 I think)
- VZM31 (zigbee dimmer)
- VZM35 (zigbee fan switch)
I am new to Homey Pro and my first switch is Inovelli Blue. I was able to pair and add the first switch but when I try to go directly to the device in the homey app and control the light, it does not turn the light on. Any suggestions?
