Humidity value cards for sustained values
I don’t understand why this flow isn’t working, it’s in Spanish but it’s simple. If humidity stays above 85 % for 120 seconds, turn on the bathroom fan, provided the bathroom light is on.
Before, the flow was straightforward: if it was above 85 %, the fan would turn on, and it worked. But I saw these new cards and they really seem like a better option.
Any idea why it isn’t working?
Was the humidity actually continuously over 85% during the 120 seconds window?
I use the same card with slightly different parameters (80% and 30 seconds) and works perfectly.
Yes, that’s right
Maybe create a new flow, in which you add the flowcards again from the catalog (so not copying them from the existing flow).
Ohhh solved i create New and is ok!! thx
