[HOWTO] BUVA Boxstream Mechanical ventilation hack
We own a BUVA Boxstream mechanical ventilation system in our home that i wanted to automate. There is a 0-10V sensor that could be used with a simple 0-10V zigbee, zwave or 433Mhz module but you can’t use the RF module at the same time when using a 0-10V module. my goal wat to have the system automated and at the same time keeping the wall remotes.
We had a spare remote laying around that i opened up.
While looking for images i noticed some websites dare to ask €100+ for this thing. lol.
The PCB inside is easy to remove and houses a 3V battery.
I’ve used a multimeter to check voltages on the buttons and found that the normal state of a button is 0Volt and a High state of 3Volt. Hurray! the remote is ideal with a arduino type board.
I used a wemos D1 mini (or clone) It has a 3.3v output and can trigger 3.3v on it’s D pins.
Here is the overview of the schematic i used.
Here is the endresult:
I have build a simple bit of code to automate it and a simple web app to support it.
any request will respond with the simple webinterface
The following URL’s can be called from any device to controll the ventilation system:
Webinterface:
http://[IP Address]/
Mode 1:
http://[IP Address]/mode1
Mode 2:
http://[IP Address]/mode2
Mode 3:
http://[IP Address]/mode3
Mode Time:
http://[IP Address]/modeT
Mode Time x2:
http://[IP Address]/modeT2
Pairing:
http://[IP Address]/pairing
Webinterface:
Source Code:
Change your WiFi SSID and Password to make it work.
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#ifndef STASSID
#define STASSID "MY SSID"
#define STAPSK  "MY PASSWORD"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
ESP8266WebServer server(80);
void httpDefaultResponce() {
  digitalWrite(D4, 0);
  server.send(200, "text/html", "<html><head></head><body><b>Control</b><br><a href=\"/mode1\">Set Mode: 1</a><br><a href=\"/mode2\">Set Mode: 2</a><br><a href=\"/mode3\">Set Mode: 3</a><br><a href=\"/modeT\">Set Mode: 4 15 Minutes</a><br><a href=\"/modeT2\">Set Mode: 4 30 Minutes</a><br><br><br><b>Pairing<b><br>The ventilation motor allows pairing only in the first 10 minutes after getting power.<br>To pair a remote, disconnect the power cable and then reconnect the power cable of the ventilation motor.<br><a href=\"/pairing\">Start pairing.</a></body></html>");
  digitalWrite(D4, 1);
void cleanStates() {
  digitalWrite(D0, 0);
  digitalWrite(D1, 0);
  digitalWrite(D2, 0);
  digitalWrite(D3, 0);
void setup(void) {
  pinMode(D0, OUTPUT);
  pinMode(D1, OUTPUT);
  pinMode(D2, OUTPUT);
  pinMode(D3, OUTPUT);
  pinMode(D4, OUTPUT);
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  digitalWrite(D1, 1);
  if (MDNS.begin("esp8266")) {
    Serial.println("MDNS responder started");
  server.on("/", httpDefaultResponce);
  server.on("/mode1", []() {
    httpDefaultResponce();
    delay(200);
    cleanStates();
  server.on("/mode2", []() {
    digitalWrite(D2, 1);
    delay(200);
    cleanStates();
  server.on("/mode3", []() {
    digitalWrite(D3, 1);
    delay(200);
    cleanStates();
  server.on("/modeT", []() {
    digitalWrite(D0, 1);
    delay(200);
    cleanStates();
  server.on("/modeT2", []() {
    delay(2500);
    cleanStates();
  server.on("/pairing", []() {
    delay(7000);
    cleanStates();
  server.onNotFound(httpDefaultResponce);
  server.begin();
  Serial.println("HTTP server started");
void loop(void) {
  server.handleClient();
  MDNS.update();
Thanks very much for your contribution! This was a long-cherished wish of mine. Followed your guide and it works great. Never have to shout upstairs again when the kids forget to turn the ventilation high when taking a shower ;-).
Hi Niels,
Thank you for sharing! I have been looking for something like this for couple of years.
I am a noob on this subject. Could you explain step by step what i have to do to make this work? And can i control the buva with an android app after this? How? And can i use google home to control the buva?
Thank you!
The image shows the solders you need to make
The code you can just use in Arduino IDE. If you’re a “noob” then I would advise to check around if friends or family have a better understanding of what needs to be done. And ask them to do this for you. Reason is that all info you’ll need is allready here and you might unintentionally break something in the process
Great idea Niels! Wanted to let you know that the Home Assistant forum raised exactly the same problem as you did, but leaving room for solutions to the problem of losing base functionality.
I therefore shared your post on the HA forum: https://community.home-assistant.io/t/how-to-automate-this-mechanical-ventilation/125837/18
Let me know if you want this post to be altered in any way, to be fair, it is still your idea after all.
Thanks @Rik_Muilwijk no need to change anything. I’m not sure if it’s a feasible solution for the base controller though, i mean if you meant the 230v powered in walled pannel solution. I could have a look at it if i can find it somewhere. I removed mine and put a custom build touch pannel there, so i’m not using it anymore.
Looks great, but how do I control it from Homey (can you make an example please)
Ah, thanks v.m.
Did you for any chance find out what the J1 and J2 headers are for on the board?
To whom is your question?
To what board is your question?
To the original poster of the solution. I noticed the J1 and J2 pins on the SYSTEC board and wanted to know if they had any special function.
J1 and J2 are probably Jtag ports for debugging. didn’t investigate as i wanted a quick and easy fix and not another can of worms :slight_smile:
Thank you for the code! I have the original switch now permanently on a 5v usb charger hanging somewhere in the house and 3d printed a backshell for the original switch.
I installed a Moes / Tuya 4 gang wall zigbee switch from Aliexpress with sticky tape in the bathroom and programmed the 4 switches with Logica http get and connected a Tuya temperature and moisture sensor to it. So i can control it manually or it starts automatically when i the moisture % comes above 70%.
Used the Tuya Zigbee app and Countdown app on HP2023.
