Which flow must I use when I want to trigger a Fibaro plug when my power usage is more than -800 W. So if the total power usage is - 800 W or more, due to my solarpanels, I want to trigger a Fibaro plug to on. I have a P1 meter from Honewizard.
I tried the flow in the picture, but it does not seems to work.
“or less”
I am struggeling with the term higher or lower. I want to trigger the plug when I deliver more than 800 watt back to the grid. My current flow is in Dutch, so it says (kleiner) which is lower than - 800 W, or should I use (groter) higher than - 800 W
-1000 is smaller / less than -800
-400 is higher / more than -800
So to me your flow trigger is OK.
