I have an old style hood above the stove, when it is turned on the power usage will rise.
I also have an ventilationsystem, I want to turn this in high mode when the hood is turned on.
I want to try this with the Fibaro wall plug with the internal power usage sensor.
Then make an flow like turn on the ventilationsystem when the power usage comes above 100 watt for example.
Does anybody knows if it is possible to built an flow on the power usage sensor or this can be done at a different way?
thnks
