Does anyone have an idea which (easy) device I could use in the kitchen to detect when I turn on the ventilation system above the stove?
I think that could create some great flows for when I start cooking, I’ve searched but I can’t seem to find an easy device that would enable this (if it exists)!
I did smart ventilation out of the regular one. I used 2 fibaro double relays to control it (3 fan levels and one light). You can control it with original buttons, with remote or with app.
Above the stove, under ventilation, there is Aqara temperature and humidity meter. As soon as there is increased humidity or temperature level, exhaust will starts automatically. It works in most of the cases.
Not much to share. You just add smart relays to buttons (if possible) or replace buttons with them and you are ready to go. You can use fibaro relays, or shelly 1 relay.
