I like to try this Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm - Share your Projects! - Home Assistant Community I have some vasco stuff which is basically same as honeywell but is this doable with the homey rf 868 mhz module. I think the new homey does not support 868 anymore but also have the current homey pro .
Don’t know the limitations of the homey rf module. I tried to capture it but did not find anything.
thanks Edwin
besides this there is also a somfy way with Honeywell HGI-80 usb to rf way https://service.somfy.com/downloads/nl_v5/honeywellevohome_installatie_2016_nl.pdf
I don’t know if @Adrian_Rockall can add this or I can try and submit a PR.
for above I need to program/ flash firmware 1st on this SSM-D2 so I guess it won’t work on homey.
If it’s reported by the Somfy API then I can probably add support for it in the app.
Edwin_Biemond:
Honeywell HGI-80
yeah, but it seems like Honeywell HGI-80 is EOL plus very hard to get and I don’t know if it check for a real EvoHome serial. I heard you can do a fake one. will check more else will do it the home-assistant way
Going for nanoCUL 868MHz Mini-USB with FTDI Chip Honeywell Evohome Monitoring - Showcase - OpenEnergyMonitor Community
Not for HGI80 EOL and really hard to get and expensive.
Not for https://indalo-tech.onlineweb.shop/ they are in the uk and customs is annoying
Not for the seeed studio like rfbee and UartSBee they are out of stock Controlling a Honeywell BDR91 boiler relay with an RFBee or HGI80 – Matt's Tech Pages
ordered nanoCUL and next week i will flash it with evofw3 ,tune it and then do ramses_rf and ramses_cc on HA
