Homey vs. Home Assistant – What Does Each System Do Better?
There are almost no smart home manufacturers which don’t run their service on AWS or another large company’s cloud. The only one I can find is KlikAanKlikUit (Trust Smart Home), they have a truly independent (Dutch) cloud. Somfy also gets close since their service runs on a French provider, but their authentication still needs AWS.
However, mentioning that “big tech ruined the cloud” while they’re still dependent on a Big Tech cloud is just strange to me. Fix it first, only after fixing you can change the name
You can install apps without our cloud using Homey CLI and our mobile app can connect locally to your Homey Pro? :sweat_smile:
And just to be clear: Nabu Casa is fully dependent on AWS. While the ui.nabu.casa domains are hosted on DigitalOcean, the service that hosts the tunnel, the webhooks service, authentication and account management and their website are all on AWS.
But even their ui.nabu.casa domains need AWS, since they use AWS for the DNS.
If only apps were required to be Open Source…
Sven, seriously — how many times does this have to be explained before it finally gets through?
HOME ASSISTANT IS NOT DEPENDENT ON AWS, NABU CASA OR ANY OTHER BIG TECH CLOUD.
An optional service offered by Nabu Casa may use AWS or whatever infrastructure they choose. That does not make Home Assistant dependent on it.
This distinction has now been explained to you over and over again, probably twenty times.
At this point there are really only two possibilities: either you genuinely still don’t understand the difference between using a service and depending on a service, or you deliberately ignore that difference because otherwise your entire argument collapses.
Here is the simple version once again:
  • I can buy an iPhone and subscribe to Spotify.
  • Spotify may run entirely on Big Tech cloud infrastructure.
  • If Spotify disappears tomorrow, my iPhone still works.
Therefore my iPhone is not dependent on Spotify. Exactly the same with Home Assistant:
If Nabu Casa Link or the infrastructure behind it disappears tomorrow, my HA installation keeps running. My devices work. My automations work. My local integrations work. My Companion App works locally.
I lose the optional services provided through Link.
That’s it.
So please stop repeating this nonsense that Home Assistant is “dependent on Big Tech cloud” because one optional Nabu Casa service happens to use cloud infrastructure.
It is factually the same argument every single time, and changing the wording doesn’t make it any less wrong.
If after twenty explanations this distinction still doesn’t reach you, I honestly don’t know what else anyone here is supposed to explain.
You are right that apps can technically be installed without the App Store using Homey CLI.
But that is not the same as saying that a normal user can simply install any Homey app without Athom’s cloud.
To do that, the user first needs to install Node.js, install the Homey CLI, and have access to the complete app project/source code.
And that last point is important: many developers do not publish their source code. I don’t publish the source of all my apps either.
So yes, CLI installation exists, but only if the app’s code is actually available to the user. For closed-source apps, the App Store remains the only realistic installation path.
Regarding the mobile app, I may have based my statement on older reports, so I’m happy to correct that if things have changed.
What I would like to know is this:
Can the Homey mobile app authenticate completely locally when Athom’s cloud is unavailable, including when the existing authentication token has expired?
Or does the app only communicate locally with Homey Pro once authentication has already been established through Athom’s cloud?
That distinction is the important one for me.
Did you even read my post? Home Assistant isn’t dependent on Nabu Casa, but Nabu Casa is fully dependent on a big tech cloud (AWS), while they say that “big tech ruined the cloud” and then it’s hilarious that they use Amazon for their cloud service :rofl::rofl::rofl:
j1nZ1CmLDx7MliJt4Q
You’re turning the discussion around again.
Who cares which infrastructure provider Nabu Casa uses?
The point is what “cloud” means from the user’s perspective.
I avoid cloud dependency. I don’t care whether an optional service runs on AWS, Azure or somewhere else.
A service provider depending on infrastructure is not the same as my smart home depending on that service.
If Nabu Casa changes provider tomorrow, nothing changes for me. If Nabu Casa disappears tomorrow, my smart home still works locally.
That is the whole point.
Back to the topic.
One major advantage of Home Assistant, in my opinion, is its organizational structure.
Nabu Casa is a US-based commercial company. It develops and sells the official Home Assistant hardware and Link services and helps fund development. It has made very clear commitments regarding privacy and independence.
But in the end, those are still commitments made by a company. Management can change, priorities can change, and theoretically Nabu Casa itself could one day be acquired by a large company, just as Athom was acquired by LG.
The big difference is:
Buying Nabu Casa does not mean buying Home Assistant.
In 2024, Home Assistant was transferred to the Open Home Foundation, a Swiss non-profit foundation built around three principles:
  1. Privacy
  2. Choice
  3. Sustainability
The Foundation is still mainly financed through Nabu Casa, but it has already started building additional partnerships to diversify its funding and reduce its dependence on any single commercial partner.
And there is another important layer of protection beyond that.
Home Assistant Core is open source under the Apache 2.0 license. So even if the Foundation itself disappeared one day, the existing code would not disappear with it. Anyone can legally use it, fork it and continue developing it.
The Foundation controls the official project, branding and trademarks, so a fork could not simply continue under the Home Assistant name. But technically the project itself could continue under another name.
That makes the structure fundamentally different from a proprietary platform owned by a single commercial company.
You would have to lose Nabu Casa, the Open Home Foundation and the contributor community before Home Assistant as we know it really disappeared — and even then the source code would still exist and could be continued.
Of course, nothing is guaranteed forever. But the history of large open-source projects shows that projects with a huge user base and a large contributor community are very difficult to simply kill.
For me, that organizational and technical independence is one of Home Assistant’s biggest long-term advantages.
So is that the reason Athom continues with misinformation, because the average consumer, “don’t even have a clue”
That is not something to brag about on a public forum
I would definitely argue that your takes are often pretty clueless, but that’s beside the point.
Please try to keep your posts relevant and actually contribute to the discussion at hand. I think you’ve been reminded of the forum rules more than enough times by now.
homey’s advanced flows are superior. some ha integrations are way better then their counterpart on homey and the other way around, so i use both. ha has a steep learning curve, but has no license cost. homey (shs) is easy, but comes with a license cost. ha can be fully standalone, and homey need a cloud component (for authenticating) In the end what is deployed must be family proof, the light must still switch on, even if all that tech fails. also, i think that homey is much better to serve both tech and non tech users. would be fun if homey shs style, will be available on lg tv’s
That really depends on what you mean by “tech users”.
My experience is that Home Assistant allows me to build automations that would become far too complex in Homey.
With Advanced Flow, the wiring can become so wild that following one possible automation path gets increasingly difficult. In Home Assistant, a well-structured Choose block can make even quite complex logic much easier to follow because every possible path is grouped clearly.
But the biggest difference for me is Helpers and Templates.
In Homey, I largely depend on the capabilities and Flow cards that an app or device provides.
In Home Assistant, I can often create missing functionality myself on the fly.
A simple example would be a sensor that doesn’t provide something like “state unchanged for X minutes”. I can create a derived sensor from the live state and use that instead.
And with Templates I can go much further, including fairly complex calculations and exposing the result again as a normal sensor that can then be used everywhere else.
So for a non-technical user, I can absolutely see why Homey may feel easier.
But for a technical user who wants to go beyond what integrations and apps already provide, I would say Home Assistant offers considerably more freedom.
true, but do not rule homey out. with the javascript cards in advanced flow for example, a lot is possible. or homeyduino to integrate arduino’s. on the other side of the spectrum, my non tech 85year old dad is able to configure some homey light flows all by himself , noway he could do that in ha. thanks to claude i start using ha more and more, but like i said before, i use both, each with their strength and weaknesses.
i have homey dashboards with iframes served by ha and prtg, and soon i migrate shs to the ha homey shs addon.
I think my wife would probably struggle to create automations in either system. :wink: But to be fair, most basic light automations are simple once you understand the general smart-home concept.
Today, I actually think they require about the same effort in Home Assistant as in Homey, and in some cases even less. The current HA automation editor is conceptually very similar to a normal Homey Flow, with three very clear sections:
Triggers – Conditions – Actions
And each section has a good explanation of what it does. If you only want something simple, you basically click, select a trigger and then select an action. Of course, if your trigger is a motion sensor, you normally also need logic to turn the light off again. But that is true in both systems.
Initially, I thought one major advantage of Homey Advanced Flow was that I could put several related simple flows on the same canvas. So instead of creating one Flow to turn the light on and another one to turn it off, I would put both pieces of logic into one Advanced Flow.
Then I realised that I can do something very similar in HA. I can add several triggers to one automation and then use a Choose block with conditions such as “Triggered by…” to decide which path should run. So the logic remains grouped together there as well.
And once an automation grows, I actually find that approach increasingly readable. Several clearly named triggers combined with structured Choose blocks are, for me, often easier to follow than a large Advanced Flow with many connections crossing the canvas.
And if I have to start writing JavaScript inside Flow cards to achieve more advanced logic, then I might just as well use YAML and Jinja in Home Assistant. At that point, we have already left behind the simplicity that Homey is supposed to provide.
I also used Hubitat before, and one of the reasons I left was Rule Machine. It was much more powerful than Homey’s Advanced Flows, but the interface felt like something from the Windows 98 era, and editing existing rules was painful.
That is where I think Home Assistant is interesting today:
It can be as simple as a normal Homey Flow for basic automations, but if you need it, it can scale far beyond that without forcing you into an entirely different automation system.
I am not giving up Homey because it is a bad system — it definitely isn’t — but because, in my setup, it no longer gives me any real added value. If Homey had been stable with my Matter devices, I probably would never have started using Home Assistant in the first place. But now that I have seen how much more powerful HA can be, and that even complex automations can actually become more readable than large Advanced Flows, I simply no longer feel any motivation to keep using Homey.
But to stay on topic, I will let it run as TBR and to maintain my apps. Maybe one day, Homey’s evolution goes in the right direction and I may reconsider my actual decision. Or my kids may reuse Homey once they take over.
Homey has Dashboards and Insights, but Home Assistant has Lovelace dashboards with a huge number of available card types and very powerful statistics.
More importantly, Home Assistant has Helpers and Template Sensors, so if a device does not expose exactly the value I want, I can often create it myself and then use it like any other sensor.
For example, I have a temperature card for every room like this:
It shows:
  • outside temperature
  • target temperature
  • room temperature
  • temperature measured by TRV 1
  • temperature measured by TRV 2
  • heating state / mode
The dashboard card itself is a built-in Home Assistant card, not a third-party card.
Some of these values come directly from devices, but others are created using Helpers.
For example, this creates a sensor representing the current heating target temperature:
template:
  - sensor:
      - name: Heizung Bad Soll
        unique_id: heizungsverlauf_soll_bad
        unit_of_measurement: "°C"
        device_class: temperature
        state_class: measurement
        icon: mdi:thermostat
        availability: "{{ states('climate.badezimmer_heizung_bad') not in ['unavailable', 'unknown'] }}"
        state: "{{ 0 if is_state('climate.badezimmer_heizung_bad', 'off') else state_attr('climate.badezimmer_heizung_bad', 'temperature') | float(0) }}"
You can create the Template Sensor through the visual interface, although the formulas for state and availabilitystill have to be entered manually.
In this case, that is basically just two small Jinja expressions — and AI can generate those very easily.
The important part for me is what happens afterwards: the result becomes a normal Home Assistant sensor. I can display it on dashboards, use it in statistics, history graphs, automations, conditions, calculations, or anywhere else.
That is something I find very powerful.
If an integration does not expose exactly the information I need, I am not necessarily dependent on the integration developer adding it.
For example, I did not have a directly usable historical value for the TRV heating state/mode in either Homey or Home Assistant. In HA I can simply create the missing sensor myself and start recording its history.
I don’t see a comparable way of doing that in Homey if the device or app does not already provide the corresponding value for Insights.
And this is one of the fundamental differences I see between the two systems:
Homey mainly lets me work with what apps and devices expose. Home Assistant also lets me create new data from the data I already have.
What about the option in Homey to create a virtual device (e.g. via the Device Capabilities app) in which you can create your own devices and capabilities, and have them logged via the standard Insights functionality?
That’s a fair point. With an app like Device Capabilities you can indeed create virtual devices and your own capabilities in Homey, update them through Flows and have the resulting values stored in Insights.
So saying that Homey cannot create derived data at all would be incorrect.
For me, however, there are two important differences.
The first is “without a third-party app”.
In Home Assistant this functionality is part of the platform itself. I can create a Template Sensor or Helper and the result becomes a normal entity with history and statistics that can immediately be used in dashboards, automations, calculations, etc.
The second difference is what I can put behind that sensor.
The value does not simply have to be copied from somewhere else. With Jinja I can calculate it dynamically, combine several entities, apply mathematical formulas and use if/then logic to transform the value before it is stored.
That is exactly what I do with the target temperature in my graph. When the TRV is switched off, I don’t want its normal target temperature to appear in the graph, so the template returns 0 instead:
And this can become much more complex if necessary. The result is still simply another sensor as far as the rest of Home Assistant is concerned.
I don’t see a comparable native mechanism in Homey where I can define an arbitrary calculated capability with conditions and formulas and have it behave like any other system value.
Of course I could probably reproduce much of it with Device Capabilities, additional Flow logic, Better Logic or HomeyScript. But then I am relying on third-party apps or JavaScript to recreate functionality that Home Assistant provides as part of its standard platform.
So I would correct my earlier statement to:
Homey can create derived data as well, but Home Assistant makes calculated and transformed data a native building block of the system.
“Starting with Home Assistant 2026.11, HACS is built into Home Assistant and called the Marketplace”
And another very cool dashboard feature is coming with 2026.11: native automatic sections.
I already built something similar for my dashboard using auto-entities, but from 2026.11 onward much of this can be done directly in the graphical editor, without YAML or Jinja.
The basic idea is simple: you define include and exclude filters.
For example, a section can include:
  • everything from the climate domain
  • devices containing “Heat” in their name
  • everything carrying a label such as TRV
And if there are devices you don’t want in that section, you can explicitly exclude them — for example by giving them a label such as no-dashboard.
The really powerful part is the label system.
Labels are completely independent of rooms, device types or domains. I can create my own label, assign it to any combination of devices or entities, and let the dashboard dynamically build a section from that.
So I can group things according to how I want to use them, not according to how the manufacturer or integration happened to classify them.
And when I later add another device with the same label, it automatically becomes part of that section.
I already do this today with custom cards and some code. What I find exciting is that Home Assistant is now bringing this kind of dynamic dashboard building into the native UI.
