High density Thread is a dream with HA and the ZBT-2.
65 devices (one offline due to redecorating) playing nicely, all of the time.
Itjusssweeeeeeerks
Yes my Homey SHS continuously drops my matter devices while they still are available in Apple Home and Home Assistant. It has gotten so bad that I am in the process of migrating my devices to Home Assistant
Here is mine:
And this is my Matter network. The devices on the right that are not connected to the Thread mesh are simply Matter-over-Wi-Fi devices.
I currently have 78 Matter devices.
Today, three of them are missing in Homey, while none are missing in Home Assistant.
One thing I especially like in HA is the diagnostics.
I have a dashboard tile that counts unavailable devices. With one click, it opens a list showing which devices are missing, since when, and their relevant IDs, so I can immediately check the corresponding logs.
And in the network views, clicking on a node exposes a large amount of useful information about that device and its connections.
For debugging Thread and Matter, HA is really a dream compared with what I currently have available in Homey.
I still hope Homey will eventually solve these occasional Matter drops and, just as importantly, provide much better diagnostic tools — either directly to users or at least internally for support.
I did the same, although I also have to defend Homey a little here.
I had some very severe outages where more than half of my Matter devices became unavailable, and on rare occasions almost all of them disappeared. I eventually reset every single device, paired it first with Home Assistant, enabled Matter Multi-Admin pairing, and then paired the same device with Homey as well. So today all my Matter devices are paired natively with both controllers.
Even after that, I still had some major outages. In one case more than half of the devices disappeared from Homey, while roughly a quarter disappeared from HA. So HA clearly handled the situation better — but losing a quarter of the devices still isn’t what I would call a reliable Thread network.
The big advantage was that HA gave me the diagnostic tools to understand what was actually happening. During those outages, the logs showed repeated “Thread channel not accessible” errors. Seeing such an error occasionally is not necessarily a problem. It can simply mean the channel was busy and the transmission is retried. But I was seeing chains of 50+ of those messages, followed by one successful transmission, then another long chain.
That made RF interference a very strong suspect. I then used the Omada Wi-Fi analysis tools and eventually identified my own Eufy camera system as the culprit, not Homey.
The Eufy HomeBase creates a hidden Wi-Fi network for the cameras and automatically changes its channel. Unfortunately, there is no way to lock that network to a fixed channel. When the problem occurred, unplugging and restarting the HomeBase would very often make the Thread network recover almost immediately.
So one of the biggest problems in my house wasn’t actually caused directly by Homey — it was Eufy creating interference.
The interesting part is how the two systems reacted to the same bad RF environment. Home Assistant with the ZBT-2 was affected too, but considerably less. So in my environment, HA appears to cope better when Thread conditions become poor.
I still occasionally lose one or two devices in either system. Those are mostly inexpensive IKEA devices. My suspicion is that some of them may have weaker radios, immature firmware, or occasionally remain attached to a poor parent instead of recovering cleanly. Usually removing and reinserting the battery brings them back immediately.
But there is one important difference: Apart from those rare device-specific drops, HA is now stable for me. Homey, however, still loses a few Matter devices almost every day. Most of them return after a few hours. Sometimes I have to restart the device, and very rarely I need to repair it. Because Homey is no longer my productive system, that is now more of an observation than a serious problem for me.
My conclusion from all of this is:
Homey seems more sensitive to RF interference and marginal Thread conditions than Home Assistant with the ZBT-2.
Whether that can be improved entirely in software, I don’t know. But weak individual device radios shouldn’t normally be such a major problem in my network, because I have a very high density of Thread routers — typically two or three per room.
What makes these remaining Homey device drops even stranger is that I currently have six Thread Border Routers in the same Thread network.
So even if Homey’s own Thread antenna or radio performance were weaker, that should not really explain the problem.
Homey does not need to reach the Matter-over-Thread device directly over its own Thread radio. As a Matter controller, it should also be able to reach the device over the LAN through one of the other Border Routers in the Thread network.
That is why I increasingly doubt that these remaining drops are simply a radio-range problem.
If the same Matter device remains perfectly reachable from Home Assistant through the same Thread mesh while Homey reports it as unavailable, I would rather suspect something higher up in Homey’s Matter stack — session recovery, subscriptions, IPv6 routing/discovery or how it reconnects after a temporary communication problem.
Of course I may be missing something here, but with six Border Routers available, blaming Homey’s own antenna alone doesn’t really make sense to me.
