You should report to Athom support: Support | Homey
Select “My .. is not listed” to reveal the submit form.
Did anyone have this error on a Mac while starting up the SHS?
Startup time out: service did not become healthy.
I rebooted, removed Mac caches, even removed a suspicious app that crashes (the Arlo Community app crashes on booting, so I suspected that one was the culprit). Any idea?
Why does this constantly happen when I try to reach homey remotely?
Tried with and without port forwarding, please help
Something went wrong, please try again.
Timeout after 10000ms
Same problem here. It only works via VPN.
@Nick_Schiffman @Wolfram_Streit
Can’t relate ..
Did you register the SHS instance by first adding it as new Homey to the mobile app?
Yes, it will load up randomly usually on the 3rd attempt
Is it constantly connecting over VPN? Mine is hit or miss over VPN as well. But always works locally
No, unfortunately not reliably. The devices are displayed, but a timeout message usually appears during the flows.
I connect remotely to my Mac Mini via VPN and use Safari browser on the Mac. Then everything works!
