Reboot Advanced flow:
Homey has started Advanced Flow:
I log to the timeline as well as to a local simplelog and a remote syslog
You can use the SimpleLog app: Simple (Sys) Log App for Homey | Homey
My setup is slightly more advanced, since I am also running a centralised syslog on my synology. But if you drop the two cards that say ‘DS920’ your flow should still work locally on you own Homey.
Remember that when using apps, also logging apps, they need some time to startup. This is why I have the 30s delay after the reboot. Experiment with timing on your local device to make sure this works properly and you don’t encounter that SimpleLog has not started yet. If it does not work, increase the delay.
