Are you willing to loan or donate a device to a developer?
devices are integrated into kitchen
Iām willing to donate
** Extra information: **
The devices are integrated into my Homey Zigbee network. Interview results via the Homey developer site can be shared (or any other usefull information).
What kind of brand/device(s) would you like to be added: carrier airco
Brand name, and any (available) id number(s)/types of devices
What kind of category/signal(s) would the app use:
IP /wifi
**Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)? There is an ecsisting app in the app store to control the airco (carrier)
Flo by Moen https://www.moen.com/flo
Is a stop valve for the water main, that also measures flow, pressure, meters consumption and can detect leaks.
IP (Local/Cloud/WiFi)
There is no public API, but there is apparently an integration of the device with Hubitat, Home Assistant and with SmartThings, as well as an MQTT workaround through homebridge
Adaprox, fingerbot (the cheap Tuya versions would also be nice)
At this moment I control also a cheap AliExpress version via the Adaprox app directly from my Android phone. Buy I would like to control them via Homey.
Bluetooth
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)? https://developer.tuya.com/en/demo/fingerbot
This item claims that de Adaprox Fingerbot can be controlled via the Tuya app, but than the bluetooth version.
extra info, bestway already has its own application with which you can turn the jacuzzi on/off, set the temperature, turn on/off the circulation pump. would like to see this in homey. jacuzzi itself sends all the wifi signal to connect in the bestway application
**What kind of brand/device(s) would you like to be added:**
Bosh Indego Connect Mower (S+ 350)
**What kind of category/signal(s) would the app use:**
WIFI/Cloud
**Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?**
https://github.com/zazaz-de/iot-device-bosch-indego-controller/blob/master/PROTOCOL.md
**Are you willing to loan or donate to a developer?**
- Yes, donate a device
**Extra information:**
It works well with Home Assitant :slight_smile:
Philips Fidelio SoundBar, model: B97/10 and other modles in that range
IP (Local/Cloud/WiFi), this one is preferred
Nothing found, but when scanning the ports several open ports where found and there are android and ios apps for these devices. Also the devive is found as upnp device and supports play-fi protocol
Link(s) to where can this be found, the more information, the better.
Nooie PE10 smart plugs
IP (Cloud/WiFi)
I do not think so
Yes, donate money ā¬
Extra information:
The plugs are compatible with Alexa.
I donāt know if these devices can be added to SmartLife or some Tuya app. Currently I can partially control the plugs through the Alexa App in Homey (switch on/off, but no status update).
This topic has been cleaned up:
There were 49 duplicate requests!
These have been removed.
So please first search this topic if your request isnāt already here!, and if so and you want to contribute any (extra) information please contact the original poster, or contact me via PM to update that post.
The good news: 47 app requests have been added into the app store so far.
These have also been deleted from this topic, if you donāt see yours anymore, but your device(s) (still) isnāt supported?
Please contact that developer first!
