Hi all,
Since today (5 Nov) around 15:20 CET my Homey Pro (2026), firmware 13.5.3, can barely transmit on Zigbee or Thread. Everything had been running fine for weeks.
Symptoms
- Almost all commands from Homey to Zigbee devices (IKEA, Sonoff, Eglo, Sunricher, Philips) and to Matter-over-Thread devices (IKEA GRILLPLATS/KAJPLATS etc.) time out or fail with “device unreachable”. This includes a Thread plug 2 m from Homey.
- Incoming traffic partly works: sensor reports and Hue dimmer presses still arrive, but commands back out do not.
- Right after every boot, things work for 1–2 minutes, then stop. After that only short random windows where a few commands get through.
- Zigbee and Thread both report “ready”, no errors. Z-Wave is fine.
- The Homey process shows high CPU (often 50–90%) and memory going 600–700 MB.
What I’ve tried (no change)
- Reboot, cold boot (unplugged 30 s), and cutting power to the whole house via the main breaker (twice)
- Router reboot; 2.4 GHz Wi-Fi locked to channel 1 (Zigbee/Thread are on channel 20)
- Running Homey without Ethernet
- Disabling my own apps, the IKEA app, and the flows changed today
- Unplugging the devices added today (an IKEA GRILLPLATS and a Telldus Z-Wave plug), removing 8 IKEA GU10 bulbs, and pulling the batteries from the Hue dimmers I used when it started
- Unplugging all 4 Google Nest Hubs (they have their own Thread network)
I tested once with Homey moved to another room. Zigbee seemed to work there, but it may just have been the window right after boot.
Setup: ~76 Zigbee nodes, 69 Matter/Thread nodes (mostly IKEA), a few Z-Wave devices.
Has anyone seen this? Any idea what could make Zigbee and Thread stop transmitting at the same time, and keep failing through full power cycles? A support ticket with a diagnostic report has been sent to Athom.
Thanks!
