[Homey Pro 2023/2026/mini] Informationen und Diskussionen zu neuen Firmware-Updates
Achtung, HomeKit-Experiment-Nutzer: Schaltet das HomeKit-Experiment auf keinen Fall mehr aus. :face_with_peeking_eye:
Homey Pro v13.5.1-rc.6 has been released to the beta channel.
Core
  • Improved diagnostic and troubleshooting capabilities for Zigbee and Thread.
Erscheinungsdatum: 24.09.2026
Laut Abe (Athom) wird das HomeKit-„Experiment“ durch die Matter Bridge-App ersetzt
Homey Pro v13.5.1-rc.7 has been released to the beta channel.
Zwave
  • Fix in Z-Wave Security S2 for Zooz devices
Erscheinungsdatum: 25.09.2026
v13.5.1
Core
  • Security fixes.
  • Improves diagnostic and troubleshooting capabilities for Zigbee and Thread.
Devices
  • Fixes an issue where changes to a device group’s members were not saved when its icon was changed at the same time.
  • Fixes an issue where removing a device from a group could leave its group membership inconsistent.
Flow
  • Fixes an issue that caused mismatched Flow cards value placeholders to be displayed in the Web App.
  • Fixes an issue where data passed when starting an Advanced Flow through the API was ignored.
Moods
  • Fixes an issue where a Mood could fail to determine its Zone when a device referenced a missing Zone.
HomeKit
  • Hides the HomeKit experiment when it is disabled. Existing enabled setups continue to work, but the experiment cannot be enabled again after disabling it.
Matter
  • Fixes an issue where some device data could occasionally fail to update correctly.
  • Adds support for Chime, MeterIdentification and SoilMeasurement clusters.
Z-Wave
  • Fixes an issue with Z-Wave Security S2 for Zooz devices.
Apps
  • Fixes an issue that could cause Homey to freeze when starting apps with an extreme amount of drivers and Flow cards.
28.9.26
Vielen Dank an @SunBeech, der „den richtigen Knopf gedrĂŒckt“ hat – nun werden endlich die Veröffentlichungstermine der Firmware zusammen mit dem Changelog angegeben @ https://homey.app/en-us/wiki/homey-pro-firmware-changelog/
Homey Pro v13.5.2-rc.4 has been released to the beta channel.
Core
  • Improves error handling when Homey’s name exceeds the maximum length.
Flow
  • Fixes an issue where Flows created without card groups could fail to open in the Web App or mobile app.
  • Fixes missing dropdown option titles in Flow cards from older apps.
Z-Wave
Apps
  • Improves isolation of Python apps.
Thread
  • Fixes an issue where all Thread devices could become unreachable due to an occasional address conflict between Zigbee and Thread.
  • Fixes an issue where all Thread devices could become unreachable if Homey Pro is connected to both Ethernet and Wi-Fi.
  • Improves reliability when multiple Thread Border Routers are on the same Thread network as Homey Pro.
Erscheinungsdatum: 08.10.2026
Homey Pro v13.5.2-rc.5 has been released to the beta channel.
Core
  • Restored firmware for Homey Pro Ethernet adapters which may improve reliability.
Erscheinungsdatum: 12.10.2026
Homey Pro v13.5.2 has been released to the stable channel.
Core
Flow
Z-Wave
Apps
Thread
Erscheinungsdatum: 15.10.2026
Homey Pro v13.5.3 has been released to the stable channel.
Security
  • This release includes an important security fix. We recommend keeping your Homey up to date.
Core
  • Updates translations.
Energy
  • Fixes an issue where energy reports could be duplicated or temporarily show outdated values.
Flow
  • Fixes the “Set lock mode” action card, which did not apply the selected mode.
Erscheinungsdatum: 21.10.2026
Diese Punkte gibt es als UND und DANN Karte seit dem letzten Update, zumindest ist es mir jetzt aufgefallen.
Weis jemand was das ist?
Das hat die KI rausgefunden.
manager.schedules.names ist der unĂŒbersetzte Gruppenname eines neuen Homey-Systemmanagers, Schedules. Die eigentlichen Karten stehen dahinter und sind noch auf Englisch.
Auf dem Homey Pro (Early 2023) ist seit Firmware 13.5.3 (Beta-Kanal) der Manager homey:manager:schedules dabei. Die App soll die Gruppe Schedules nennen. Der SchlĂŒssel dafĂŒr ist manager.schedules.name. Die deutsche Übersetzung fehlt, deshalb bleibt der RohschlĂŒssel in der Kartenliste stehen. In der UND-Spalte und in der DANN-Spalte ist das dieselbe Gruppe.
Dahinter liegen diese Karten:
UND
‱ A Schedule is enabled/disabled. PrĂŒft, ob der Schedule eingeschaltet ist, auch wenn gerade keines seiner Ereignisse aktiv ist.
DANN
‱ Enable a Schedule. Schaltet den Schedule ein und wertet seine Ereignisse mit der aktuellen Zeit, den Bedingungen und der PrioritĂ€t aus.
‱ Disable a Schedule. Schaltet ihn aus, ohne seine EndzustĂ€nde anzuwenden. Ein anderer Schedule kann dann ĂŒbernehmen.
Eine Wenn-Karte gibt es nicht. Schedules sind etwas anderes als die Wecker und als Datum & Zeit: ein Schedule hat Ereignisse, Bedingungen, eine PrioritÀt und EndzustÀnde, und er kann ein- oder ausgeschaltet sein, ohne dass gerade ein Ereignis lÀuft.
Auf diesem Homey ist die Schedule-Liste noch leer, und in der mitgelieferten Web-OberflÀche gibt es noch keine Seite, auf der man einen Schedule anlegt. Die Karten sind der sichtbare Anfang dieser Funktion. Solange kein Schedule existiert, hat die Auswahlliste auf der Karte nichts zum AuswÀhlen.
Ich vermute, dass es ein Bug oder ein Versehen ist, dass diese Flow Karten zur VerfĂŒgung stehen. Bei meinem HP26 heißt der Eintrag ĂŒbrigens auch etwas anders:
EDIT
Hier die BestÀtigung eines Mitarbeiter von Athom auf Slack:
(Quelle)
Homey Pro v13.5.4-rc.6 has been released to the beta channel.
Core
Zigbee
  • Fixes some Zigbee devices being listed as “Unknown Node” in Developer Tools and diagnostic reports.
  • Fixes an issue that could result in Thread and Zigbee being configured for different channels.
Devices
  • Fixes PIN protection for Google Assistant not being saved for devices.
Moods
  • Fixes HomeyScript not being allowed to set Moods.
Matter
  • Fixes Matter devices becoming unavailable when one of their endpoints is removed.
  • Controlling a capability of a removed endpoint now shows “The device no longer supports this action.”.
Erscheinungsdatum: 02.11.2026
06.11.26
v13.5.4-rc.7
Core
  • Minor improvements and bugfixes.
Zigbee
Devices
Moods
Matter
Edit:
Early23 keine Probleme. Early26 musste ich allerdings neu starten, erst dann wurde das Update installiert.
12.11.26
