DirkG
February 2, 2026, 11:08am
648
Homey Pro v12.11.0 has been released to the stable channel.
Core
Apps
Added support for new capabilities .
Updates Apps SDK to the latest version.
Fixed an issue that could cause a capability value to become out of range after rounding to nearest step size.
Flow
Improved handling of Flows with missing condition cards.
Added token with user name to presence Flow triggers.
Fixed an issue that prevented proper filtering of autocomplete options in Alarm Flow cards.
Insights
Re-enabled higher resolution for âlast hourâ Insights.
Matter
Fixed issue where Wi-Fi devices wouldnât automatically connect to Homeyâs Wi-Fi network.
Fixed issues where Matter devices would try and subscribe twice due to race when starting Homey.
Fixed issues with adding specific Matter devices to Homey (e.g. Meross and Third Reality).
Improved error handling in case Matter could not start.
Erscheinungsdatum: 02.02.2026
DirkG
February 6, 2026, 3:40pm
649
Homey Pro v12.12.0-rc.4 has been released to the beta channel.
Camera Streaming
The Web App now supports showing video streams. Playback outside your local network should also work in most cases. Streams are served via a WebRTC proxy by default, improving compatibility across frontends. Developers can opt out using the disableWebRTCProxy option (docs ). For the best experience use Homey Mobile app v9.7.1 or higher.
Core
Updated translations.
Fixed an issue that could cause Homey to crash when interacting with Insights.
Matter
Fixed an issue that could cause Flow cards for Matter devices to not work.
Erscheinungsdatum: 06.02.2026
DirkG
February 17, 2026, 12:52pm
650
Homey Pro v12.12.0 has been released to the stable channel.
Camera Streaming
Core
Matter
Erscheinungsdatum: 17.02.2026
v12.13.0-rc.3
Core
Fixed an issue where reinstalling an app could remove it if the download failed.
Apps
Device
Fixed capability values being set to slightly out-of-range values due to rounding order.
Fixed âlast seen atâ not updating correctly for some devices.
Z-Wave
Fixed an issue where migrating from Homey Pro (2016â2019) to newer versions could result in Z-Wave nodes not being migrated correctly.
Zigbee
Devices that previously left the Zigbee network are now automatically made available again when they continue to communicate.
Repairing a Zigbee device with a physically different unit is now supported, as long as the model and manufacturer names match.
Various Zigbee stability improvements and bug fixes.
Matter
Improved automatic driver selection for bridged devices.
Flow
Added new multi-select Flow cards for âday/week/month and season isâ conditions.
Erscheinungsdatum: 02.03.2026
DirkG
March 4, 2026, 10:08am
653
Homey Pro v12.13.0-rc.4 has been released to the beta channel.
Core
Zigbee
Fixed an issue that could cause Zigbee to not start properly.
Insights
Fixed an issue that caused missing device names in Insights migrated from Homey Pro (2016â2019).
Erscheinungsdatum: 04.03.2026
v12.13.0-rc.5
Core
Zigbee
Minor stability improvements.
Cleanup unknown nodes in developer tools.
Erscheinungsdatum: 05.03.2026
DirkG
March 6, 2026, 11:22am
655
Homey Pro v12.13.0-rc.6 has been released to the beta channel.
Core
Erscheinungsdatum: 06.03.2026
DirkG
March 9, 2026, 4:29pm
656
Homey Pro v12.13.0 has been released to the stable channel.
Core
Apps
Device
Z-Wave
Zigbee
Matter
Flow
Insights
Erscheinungsdatum: 09.03.2026
v13.0.0
Homey Pro v13.0.0 has been released to the stable channel.
Apps
Added support for the Python Apps SDK.
Core
Fixed an issue that could cause timeline notifications without text.
Erscheinungsdatum: 11.03.2026
DirkG
March 23, 2026, 4:21pm
658
Homey Pro v13.1.0-rc.4 has been released to the beta channel.
Core
Updated locales.
Fixed an issue that could prevent a disconnected Homey Bridge from being marked as unavailable.
Matter
Added support for syncing Homeyâs language with devices.
Added support for syncing Homeyâs time with devices.
Added support for EV chargers.
Added support for water heaters.
Added support for changing a sensorâs sensitivity.
Added support for dishwashers.
Added support for laundry dryers.
Added support for microwaves and ovens.
Added support for valves.
Added support for enabling/disabling a robotic vacuum cleanerâs zones through Flow.
Added continuous dimming Flow cards for lights.
Improved support for intermittently connected devices.
Improved door lock support with more modes, door-open status, auto-relock, and additional settings.
Improved support for devices with multi-phase energy/power metering.
Fixed an issue where dimming a light to 0% with a duration would ignore the duration.
Thread
Fixed an issue where devices couldnât join Homeyâs Thread network in some cases.
Zigbee
Extended functionality of generic Zigbee devices (e.g. sensors, locks, window coverings, thermostats).
Improved handling of energy metering reports for generic Zigbee devices.
Experiments
Fixed an issue that could cause the SSH Experiment to not start correctly.
Apps
Improved stability of running Python apps.
Fixed an issue that could cause an app to not install properly when being manually installed while already automatically updating.
Flow
Fixed correct step size for sunrise and sunset Flow triggers.
Erscheinungsdatum: 23.03.2026
DirkG
March 24, 2026, 5:43pm
659
Homey Pro v13.1.0-rc.5 has been released to the beta channel.
Apps
Fixed an issue that could cause an app to not install properly when being installed with Homey CLI while already automatically updating.
Erscheinungsdatum: 24.03.2026
DirkG
March 25, 2026, 4:55pm
660
Homey Pro v13.1.0-rc.6 has been released to the beta channel.
Apps
Erscheinungsdatum: 25.03.2026
DirkG
March 26, 2026, 11:55am
661
Homey Pro v13.1.0-rc.7 has been released to the beta channel.
BLE
Fixes an issue where invalid BLE characteristic UUIDâs could be returned.
Erscheinungsdatum: 26.03.2026
DirkG
March 30, 2026, 4:04pm
662
Homey Pro v13.1.0 has been released to the stable channel.
Core
Updated locales.
Matter
Thread
Zigbee
Experiments
Apps
Flow
BLE
Erscheinungsdatum: 30.03.2026
DirkG
April 4, 2026, 10:16am
663
Homey Pro v13.1.1 has been released to the stable channel.
Apps
Fixed an issue that could cause a timeout when installing or updating an app from the Homey App Store.
Erscheinungsdatum: 04.04.2026
DirkG
April 13, 2026, 10:23am
664
Homey Pro v13.1.2-rc.3 has been released to the beta channel.
Core
Improved translations.
Fixed an issue that caused the LED ring to light up during update installation even though it was disabled.
Apps
Fixed an issue where discovery conditions within the same inner array were evaluated as OR instead of AND.
Matter
Fixed a Matter specification compliance issue regarding microwave/oven control.
Fixed an issue that could cause a temporary invalid interpretation of the on/off state for valves.
Zigbee
Improved handling of IAS zone enrollment.
Fixed an issue where Zigbee devices would need to be re-paired after restoring a backup to new hardware, by restoring the coordinatorâs IEEE address.
Reduced the time required for Homey Bridge to join Homey Proâs Zigbee network as Satellite.
Erscheinungsdatum: 13.04.2026
DirkG
April 13, 2026, 3:40pm
665
Homey Pro v13.1.2-rc.4 has been released to the beta channel.
Flow
Fixes missing âcapability is true/false for durationâ Flow cards.
DirkG
April 20, 2026, 3:33pm
666
Homey Pro v13.1.2 has been released to the stable channel.
Core
Apps
Matter
Flow
Zigbee
Erscheinungsdatum: 20.04.2026
DirkG
April 20, 2026, 3:34pm
667
Homey Pro v13.2.0-rc.1 has been released to the beta channel.
Z-Wave
Official Z-Wave certified implementation.
Updated Z-Wave chip firmware to version 7.21.6.
Added SmartStart support. Devices can be added by scanning a QR code or by entering the DSK.
Added support for controlling door locks and thermostat mode/setpoint from the default Z-Wave device.
Added S2 multicast security support.
S2 now grants all requested security keys (except S0) instead of only the highest.
S0 can be enabled from the advanced settings when pairing a default Z-Wave device. Disabled by default.
If security bootstrapping fails during pairing, the user is informed and the node will be removed.
Improved handling of multiple decryption attempts for multiple security keys.
Incoming messages with too low or no security level are now ignored.
Associations are now validated against the destination nodeâs supported security and command classes.
Return routes are correctly assigned when adding associations.
When a node is removed from the network, corresponding associations on other nodes are also removed.
Association group names are now retrieved from the node and shown in the device settings screen when not defined by the app.
Battery devices are now correctly and faster put back to sleep when there is no more data for them.
When changing settings of a battery device, an estimation is given for when the device will wake up. The result is shown in the timeline.
When changing settings or associations on battery devices, the result is shown in the timeline after the device wakes up.
If a device sends a Device Reset Locally notification, it is removed from Homey after verification.
Added Inclusion Controller support.
Improved Security S0 handling.
Improved Transport Service handling.
Developer Tools
Healing a Z-Wave node now also updates return routes for all association destinations.
Added âUpdate Z-Wave Routesâ feature that performs a neighbor discovery of all non-battery Z-Wave nodes and assigns new return routes when needed.
Added âIdentify Z-Wave Nodeâ feature. The node will flash a light or make a sound.
Testing a Z-Wave node now sends a NOP command instead of BASIC GET.
The list of pending Z-Wave SmartStart inclusions is now shown and new entries can be added.
When the Z-Wave network is reset, a Device Reset Locally notification is sent to nodes in the Lifeline group.
Check the updated Z-Wave developer documentation here: Z-Wave | Homey Apps SDK
