A new dev version has been released. If anyone wants to test, please do! ![]()
Hi Mike,
dev3 installed:
- no second Homey Pro entry
- all sensors active
A new release is out! I kind of had to rush this since a lot of sensors stopped working (and it was my dumb mistake). I also added some new features like better descriptions during setup, better error messages and discovery improvements.
v1.2.1
Critical
Sensor unavailability fix: A registry filter was incorrectly skipping existing sensors, causing them to become orphaned and show Unavailable. Controls (lights, switches, etc.) worked, but sensors did not. This is a critical fix for all users who rely on sensor dataâtemperature, humidity, presence, distance, and similar capabilities.
Added
- Discovery card identification: Shows IPv4 on discovered cards (e.g. âHomey (192.168.1.32)â) so multiple Homeys can be distinguished. Falls back to âHomey (IP unknown)â when IPv4 cannot be resolved.
- Setup step descriptions: Step descriptions explain what to do, required permissions (Devices, Flows, System read), and Pro 2023+ limitation.
- Translations: Added translations/en.json for config flow to display step descriptions correctly.
Changed
- Discovery host field: Never show .local hostname or IPv6 in the host field. Resolve to IPv4 when possible; use empty when resolution fails. Default manual host changed from homey.local to empty.
- Error messages: Full error messages for invalid_auth and cannot_connect with causes and solutions, including Pro 2019 not supported. Passed directly since translation keys may not resolve in custom components.
Fixed
- Sensor unavailability: Removed registry filter that skipped existing sensors, causing them to become orphaned and show Unavailable (controls worked, sensors did not).
- Discovery suppression: Suppress discovery when an existing config entry points to the same host. Fixes âDiscoveredâ Homey showing when manually configured (manual uses homeyId, discovery uses MAC/hostname).
- IPv6 discovery suppression: When discovered host is IPv6, resolve hostname to IPv4 and compare with existing entries so discovery is correctly suppressed for already-configured hosts.
- Discovery card fallback: When title_placeholders was empty, the card showed âhomeyâ (domain). Now always shows âHomey (IP)â or âHomey (IP unknown)â.
If you encounter any errors or bugs, please report them (preferably on GitHub) or just let me know here!
All the best,
Mike
Hi Mike,
Thx for your work. Sensor are working fine but now I have a ânewâ Homey pro again. The integration of the sensors works fine so its ok for me.
Glad to hear it!
Iâm working on a fix for this. Iâve already added it to my dev branch if you want to test (available in my HACS repo)
Yeah, I think I need to add a logger in my dev build and have you (or someone) try it. Then see what kind of differentiation we have between different models so that I can suppress them in the discovery.
The problem is that before we actually authenticate with our token, we donât get the full picture.
Iâll let you know when I have something ![]()
EDIT:
It was a minor update to dev. So there is a new dev-1.3.
Once itâs installed, reboot and search for [discovery] in the logs.
There should be a âmodelâ field e.g.
'model': 'homey5q', 'version': '13.0.0'}
So I need to know the model for 2019. Iâm expecting it to be âhomey2â, âhomey2sâ, âhomey4dâ or similar.
If someone wants to give me a legacy model ID that donât have the local API then I can add that to the âUnsupported modelsâ list and we wonât have that problem ![]()
My Homey 2019 has model number homey3d if that helps.
Also, this is what I found while reverse engineering Homey SHS:
export const MODELS = {
desktop: 'Desktop',
homey1s: 'Homey (Early 2016)',
homey1d: 'Super Homey (Early 2016)',
homey1q: 'Super Homey (Early 2016)',
homey2s: 'Homey (Early 2018)',
homey2d: 'Super Homey (Early 2018)',
homey2q: 'Super Homey (Early 2018)',
homey3s: 'Homey (Early 2019)',
homey3d: 'Homey Pro (Early 2019)',
homey4d: 'Homey Pro (Early 2019)',
homey5q: 'Homey Pro (Early 2023)',
homey6q: 'Homey Pro mini',
homey7q: 'Homey Pro (2026)',
cloud: 'Homey Cloud',
shs: 'Homey Self-Hosted Server',
} as const;
Thank you both! This is probably what I needed!
Iâve added a filtering so Homey 2019 and older no longer show up in discovery.
From the mDNS logs I see that Pro 2023 sends model: 'homey5q' in the discovery properties, while 2019 and older apparently donât send a model at all sometimes. So I now:
- Ignore devices without
model- older firmware doesnât broadcast it, so we treat them as unsupported. - Ignore known unsupported models - e.g. homey3d, homey4d, homey2s, etc.
- Allow supported models - homey5q (Pro 2023), homey6q (Pro mini), homey7q (Pro 2026), and SHS.
- Allow unknown models - so future devices still show up until we know their IDs.
This is in the latest dev build. If you still see your 2019 in discovery, tell me and I can look at the logs again.
As always, thank you for testing. Really means a lot!
HOMEY_MODELS_SUPPORTED = frozenset({"homey5q", "homey6q", "homey7q", "shs", "desktop"})
HOMEY_MODELS_UNSUPPORTED = frozenset({
"homey1s", "homey1d", "homey1q", # 2016
"homey2s", "homey2d", "homey2q", # 2018
"homey3s", "homey3d", "homey4d", # 2019
"cloud",
My pleasure, Mike.
It seems you nailed it, v1.2.1-dev.4 doesnât show discovered Pro 2019s.
Observation:
When manually installing & updating the integration, my previous selection was gone, all devices were back. Is this âas expectedâ with manual updates?
To update, I rename the custom_components/homey folder and upload the updated homey folder to custom_components, followed by HA restart.
Funny, these âSuperâ models never seem to be sold
Great!
Then Iâll prepare a new main release, but Iâll wait just a bit to make sure I donât get any other errors with this version first.
The device selection is stored in the config entry (in Home Assistantâs .storage/core.config_entries), not in the custom_components/homey folder. So it should actually survive a manual update where you only replace the files and restart.
Why it might still disappear
- Removing and re-adding the integration - If you delete the integration in the UI and add it again (instead of just replacing files), you create a new config entry. That new entry starts with no device filter, so all devices are selected again.
- Integration failing during the update - If you rename/remove the
homeyfolder while HA is running, the integration can fail to load. HA may then mark the entry as failed and ask you to reconfigure. Depending on how that reconfigure flow works, it might overwrite the entry and drop the device filter (but this seems unlikely). - How you perform the update - Renaming the folder and uploading a new one can leave HA in a state where it treats the integration as needing reconfiguration, which can overwrite the stored config.
Recommendation
Use HACS for updates when possible. HACS updates files in place, so the integration stays loaded and the config entry (including device filter) is preserved.
If you must update manually, avoid removing the integration from the UI. Just replace the files, restart HA, and the device selection should remain.
Aahhhh, thanks! I knew itâs not in the custom_components/homey folder, but I didnât figure out where itâs actually stored.
This probably was what happened in my case.
I didnât disable the integration before renaming the actively used homey folder.
Itâs a plan to temporary disable the integration I think.
I know, and itâs preferred by me as well, but, after I removed it, I couldnât add the custom repository anymore, no matter what.
In a bright moment I thought âwhat if I restore a backup from when it was added alreadyâ, and this brought things to life again.
You saved my home. I was at my wits end. I wanted to bring all devices in through Homey and then distribute to homeassistant and Alexa. Alexa has the skill built in, that worked right away. I was pulling my hair out trying to find a way to expose to HA. This is perfect. THANK YOU!
Hi Heinz,
I get the mix-up, but, you ended up at the HACS âHomeyâ compound addon for the Home Assistant Community app by Ronny Winkler, which is deprecated and unrelated to this âHomey Integration for Home Assistantâ app by Mike.
In short:
Please add the repository by Mike to HACS âCustom repositoriesâ first:
Next, make sure itâs added correctly:
Now you can look for âHomey Integrationâ and install it:
Next, goto Settings > Devices & Integrations > Integrations;
Hit the âAdd Integrationâ button;
Select âHomeyâ:
See this link for the complete and extended instructions:
A quick update as well.
This integration will soon be available in the default HACS repo so that if you search for it in HACS it will show up.
Iâm still waiting for the integration to be reviewed (which Iâve been waiting on since April 2).
Once itâs available there Iâll update the guide - and let all of you know!
All the best,
Mike
I have a Problem with my Shutterswitches from Fibaro, they doesn´t show up correct in HA. You only see the power Entity not the shutter to control
Update time - and this oneâs been a long time coming!
The integration is now in the official HACS default catalog ![]()
You can search for Homey directly in HACS â Integrations - no custom repository needed. Finally merged in early July!
If youâre a new user: install v2.0.1 from HACS and set up as normal.
If youâre already on 1.x and things work: please read this before updating. Version 2.0.0 renamed the domain from homey to homey_hass. Updating through HACS without migrating will break your setup. If you want to stay on 1.x, use the separate legacy custom repo ifMike/homeyHASS-legacy in HACS - youâll only get 1.2.x updates, not 2.x notifications. Latest legacy release: v1.2.8.
1.x.x versions will only be updated with critical fixes (if any). No new features will be planned for this.
| You are⌠| Do this |
| New user | â Search Homey in HACS â install 2.0.1 |
| Happy on 1.x | â Use homeyHASS-legacy in HACS, stay on 1.2.x |
| Ready to migrate | â Follow the migration guide |
Iâll update the guide to reflect the default HACS install path.
All the best,
Mike
