Homey + Fusebox central I/O
Hey Everybody,
I’ve got all my lights & pushbuttons going through my fuse box.
I’d like to install a central I/O module in my fusebox, that
takes a signal from the pushbuttons and sends the appropiate command to Homey
reveives a signal from Homey and activates the appropiate relay ( for lights and all other stuff…)
I’ve found some ideas, but not what I’m quite looking for.
What is the best(/easiest) way?
Thanks
Hi
Haven’t use it myself but heatit has dinrail connectable io device. https://www.heatit.com/z-wave/heatit-z-din-616/
thanks,
This will help!
If you require more switches, heat-it also had a 10-fold switch.
https://www.robbshop.nl/10-schakelaar-din-rail-heatit
