Homey does not connect to WIFI
Due to a router reset, the IP number is probably changed. Therefore I lost connection to the Homey. He is still working, but connection lost. I have tried to reset by the factory reset procedure, but I can not get connection. The Homey tells me that he can not make connection.The Homey setup wifi connection is visible, and he detects it. When i try to change to the normal WIFI, connection can not be made.
Who can give advise, how to solve this?
Ruud
if Homeys setup Wifi is visible just use the normal setup procedure from a PC to re-connect to the Wifi
https://www.athom.com/en/support/KB000001
Choose to keep your settings and everything should be fine…
