My dashboard just keeps crashing. It has worked for a long time, now i works sometimes for a day. Restart app, clear cache, restart pad. Android 10.
Only one app at the pad
Please help.
Did something change recently with the way the widgets work?
If I remember correctly I could tap the entire widget to turn a light on or off. (for example)
Now when I tap a widget, it opens the details.
And in the corner there’s a small icon for a quick action.
But it’s tiny, compared to the entire widget, and requires much more precision to tap it.
Did I miss an announcement?
Apparently you can disable the quick action, but that doesn’t return to the previous situation, it just removes the tiny button in the corner…
By widget do you mean a device tile?
And did you install the test version of the upcoming new mobile app v10.0.0?
Because what you are describing is part of the test version of the new mobile app.
Ah, yes, it seems I have v10.0.0.
Apparently I’m a beta tester, I don’t remember subscribing to that ![]()
If you install the live/stable version from the app store (it will replace the test version), then test versions should not be installed automatically. At least that is how it works on iOS. I assume it is similar on Android.
Thanks guys, I’ll look into that.
But, this means that this change will come to v10? Any way to downvote it? ![]()
+1
Nice warm temperatures inside…
@Ricardo thank you for reporting this issue. It was an old issue but still very real and anoying indeed. The issue appears while editing a widget with many items. It was a problem for multiple widgets. I made a fix for it ![]()
The fix will be shipped in a future update. Obviously you need the latest Homey Mobile App version.
Once again, thank you for reporting!
I really needed a dashboard that suited my needs which was:
And sadly I didn’t really find it, so I built it myself.
Right now I have a web-dashboard that is also going to be introduced as a Kiosk for Android.
The Kiosk tablet will be added to Homey as its own device where you can send bespoke messages, themes, different dashboards and so on.
You can find it here:
Community link:
App store:
My website for the project:
