Homey Dashboards | Megathread
I second Steven’s comment. Kiosk mode on the devices of household members is not a viable solution.
Short of creating a more sophisticated user permission model, a workaround would be to add two attributes to every user: a boolean that locks the user in kiosk mode, and a default (startup) dashboard to open when the app is opened on their devices. This way, we could configure user-specific (or user type specific) dashboards, and thanks to the new dashboard navigation widget, these users would not even be limited to a single dashboard.
And most importantly, this would be a very easy implementation for Athom.
Does anybody have Athom’s ear?
Tried it a while ago but it asks to put a code on the tablet. I use Fully kiosk and each time I’m in font of my tablet it turns the screen on and shows my Homey app. If I want to use this feature I need to enter a code each time I want to look at my dashboard. So at this time I’m not really using it.
I think I will just add a shortcut to my Home Screen on the Homey app to my first Dashboard in case the Homey app does a restart or I need to restart my tablet because it only shows my Fully kiosk browser.
You can switch the code off after you switched on the kiosk mode
Thanks that works. But enabling this will also disable the close feature. Even after restart or shutdown.
To close the dashboard I need to unlock Fully kiosk and set a new code for my tablet first.
@Doekse @Emile
I also suggest to offer the possibility to add a simple PIN to activate kiosk mode. It should not always depend on the device unlock.
I have a tablet without screen lock and can’t activate kiosk mode due to missing screen lock. But I would like to use kiosk mode to force the app to open with the defined dashboard (especially after an app update/app restart).
+1
Will Homey Dashboards be coming to the Homey Web App?
At this time we’d rather spend our time on building new features, than doing the same work again for web. Homey Dashboards is more performant on mobile devices, and we did expect some people to grab an old tablet from a drawer and expect it to work. If we made Homey Dashboards for web first, it simply wouldn’t have been as performant as it is now.
For a start let me say that I really like new Homey dashboards as they are, and I can see a huge potential.
However, you mention the old tablet in a drawer - I have an old iPad Air on iOS 12.5.7 which cannot be updated to anything higher than this.
I wanted to use it for exactly the reason you stated above, but unfortunately - I cannot.
The testflight beta app requires a minimum iOS 14.
Any chance I can get it to work? :smiley:
Edit:
Sorry, it’s actually iOS 14 that’s required as a minimum (5 years old), but still, I don’t think for many people it’s that old to justify hanging it to the wall - I think it’s still perfectly usable for everyday tasks.
The homey notes widget does not work for me.
If I add a note and type something in it and then close the app, the next time I open the dashboard again the note is empty.
Not very useful for a notepad.
Is this a bug?
I would like to ask for more detailed settings for kiosk mode. Like the option to turn automatic locking of the screen and set a time for this.
Also I would like to ask for local calls of the Web-Widget. They seem not to be executed locally, as I can’t reach IPs of my VPN. It would be great, if the neccessary curls would require no cloud service whatsoever, but instead would be executed on the device directly.
Does anyone know if a widget for enrgy (the house animantion) is planned? it would be nice for a dashboard
I use it with decimals and never take the dot away but i agree it should be solved
Does anyone know a nice alternative for the buienradar web widget ?
Hi Mark.
Yesterday I got tired of waiting myself.
Copy this in the widget.
https://www.weerplaza.nl/weerwidgets/regenradar/?SXNGdWxsV2lkdGg9ZmFsc2UmSXNIRD10cnVlJlpvb21MZXZlbD03
Rogier
Another one:
https://www.ventusky.com/?p=51.76;5.27;6&l=radar
1000044657
Tap on :arrow_forward: to start these screenvideos
1000044662
I can’t see the play button
What size sinuous fill in for frame height
Cant it not automatic play
The play button is for the animations I added to my post. Some browsers don’t play them by themselves.
You have to decide what the preferred auto refresh interval should be.
I just installed it, maybe it even doesn’t need auto refresh at all.
Okay
But I see no animation…
You mean moving rain clouds?
With this setting, you can drag the hour bar to the left to see the motion:
As far as I can see, it has no automatic animation like Buienradar uses.
Uhm sad that’s what I want
@Rogier_Verheugen how does it fit in your dashboard
I’m missing something
