I built a small Homey dashboard canvas for the GitHub Copilot desktop app, using Homey’s MCP server (https://mcp.athom.com).
It shows devices grouped by room, displays available readings, and supports on/off and dimming controls for compatible lights. You can also start Flows and activate Moods after confirming the action. Other devices are shown as status-only.
The canvas is open source under the MIT license. Setup instructions and a demo screenshot are in the repository: soderlind/copilot-homey-canvas.
It’s a personal community project, not an official Homey or GitHub integration.
The repo readme contains instructions for connecting GitHub Copilot to the Homey MCP, but I’ll include them here as well:
Connect Homey MCP
In the Copilot desktop app, add a user-scoped HTTP MCP server under Customize, using the name homey and URL https://mcp.athom.com. If that server is already installed at user scope, reuse it. Homey’s official MCP connection guide documents the endpoint; its ChatGPT-specific steps are not needed for Copilot.
Go to Customize > Installed > homey > Sign in and authorize the connection in Homey’s OAuth flow. Copilot handles Homey authentication and native tool permission prompts; the extension does not need a token in its files.
You do not need the canvas above to control Homey with GitHub Copilot. For example, I inquired with Copilot:
“Based on my devices, suggest flows”, Copilot gave me these suggestions:
Battery watch: Check sensors and smoke alarms daily; notify when a battery drops below 20%, without repeated alerts. Ute reported 0%, so check its battery first.
Smoke alert and lighting: On smoke detection, send a critical phone notification and turn Stålampeand Taklampe to full brightness. This supplements their alarms; it doesn’t replace them.
Presence-aware living-room lights: Update Stuelys på so it checks both occupancy and darkness, and also turns on when someone enters an already-dark room.
Gentle night lighting: Between 00:40 and 06:00, motion turns on Stålampe at 10%. Coordinate it with the existing lights-off Flow to avoid conflicts.
Good night: A manually started Flow turns off both lights and pauses Beam, leaving Petter, Tjenna, and the water heater untouched.
High-power reminder: If Pulse stays above a chosen power threshold for five minutes, send one notification with a cooldown. Start with notifications only.
