Homey-cli skill for Claude Code - drive Homey /build flows from terminal and AI agents
I’ve been hacking on the official homey CLI together with Claude Code for the past few weeks, and the result is a skill I want to share. It runs locally, no cloud involved, and covers a wide chunk of the local API including advanced flows, raw API and HomeyScript.
The feature I use most: ask the agent “suggest some flows based on my devices” and it reads your device inventory, checks what flows you already have, and proposes ideas in a browser picker. You tick what you want, click Submit, and the agent builds the picked flows.
What’s in it
You can read everything: devices, zones, flows, apps, moods (about 50 managers via homey api). Build standard and advanced flows with the full graph editor — trigger / condition / action / start / delay / all / any / note cards. Set capability values, trigger flows, rename and move devices. Raw API for whatever the managers don’t expose directly. HomeyScript when a flow genuinely can’t do the job. Token-mode if you want to bypass the cloud entirely.
The bit I’m most glad I added: a 10-point validation that runs before every flow push. It catches the broken: false trap (Homey marks flows with dead device refs as healthy, which is exactly as annoying as it sounds).
Install
mkdir -p ~/.claude/skills
git clone https://github.com/timvdhoorn/homey-cli-skill.git ~/.claude/skills/homey-cli
And the homey CLI itself:
npm install -g homey
homey login
homey select --id <your-homey-id>
Restart Claude Code, that’s it.
How I use it day to day
Usually I open with “what else could I automate with these devices?”. The agent pulls inventory, compares against existing flows, suggests. Some are obvious (evening dim ramp), some I wouldn’t have come up with myself (Sonos auto-pause on Ring doorbell with a TV-room chime).
For specific flows it works the same way: “build a flow that turns the driveway lights on when the Ring doorbell triggers after 22:00”. The agent finds the right card IDs, builds the JSON, validates, pushes. No manual flow-card hunting.
Repo + feedback
GitHub - timvdhoorn/homey-cli-skill: Claude Code / agent skill for driving Homey Pro via the official homey CLI. Replaces the public Homey MCP and adds full advanced-flow JSON support. · GitHub — MIT.
I’m actively maintaining this and would love to hear from you. Suggestions, feature requests and bug reports are all welcome. Open an issue on the repo, drop a reply in this thread, or PR directly. Particularly keen on hearing about flow patterns the suggestion engine should know about but doesn’t yet — the current starter set only covers what I happen to own.
But the Homey MCP server is basicly the same thing, right?
Or does this skill offer more features?
The MCP is not able to list advanced flows for example. This skill is based on the MCP
Tim, thank you so much for that piece!!
Creating Dashboards by the App UI could be sometimes a really frustrating expericence… now it is so easy.
I’ve also created for me an agent loop framework for developing Homey Apps completely “headless” (means without any IDE) with Claude Code and this skill helps a lot. I will create a post here in the forum describing this whole thing, referencing your skill and also dvflw/homey-app-skill.
How I built a Homey app without an IDE — with Claude Code, Superpowers Skill, Homey-cli skill and an agentic development loop
That sounds great! Could I ask how you use the Homey CLI skill to create dashboards? I’ve skimmed the skill but I can’t see where dashboards are handled.
A short example would be super helpful.
The skill just explains Claude how to use the Homey CLI, not what the CLI is capable to do.
The CLI allows to use the full set of Homey API calls (including Dashboards).
Just ask Claude:
Use Homey CLI! Check if you can read, create or edit dashboards. Store your results in homeyclimemory.md for later sessions.
Ah, thanks! I see that now as I’m starting to test out the skill. A very good first impression, @timvdhoorn looks like this can bring som value to my setup
