Homey compatible Ceiling lights with RGB indication light?
Do you know if there are more choices there for ceiling light with RGB indication light?
I found Sailsco Matter light (https://youtu.be/yreKYUiAxFg) and it seems to be working ok.
I know the Aqara T1M but it is relatively expensive and big.
If it’s Matter certified, and using the Matter specs, it should work out of the box.
Otherwise, maybe this reveals something:
app store:
recommended devices:
It is working, adding it to Homey required to use the iOS pairing option, but that was no issue. Initially I was looking something Thread or Zigbee based since in my experience WiFi lights can be painfully slow to respond, but this one is rather fast to respond👍
