On the other hand, given that there aren’t a huge amount of apps available for Homey Cloud, perhaps they will allow it nonetheless because it will make Homey Cloud look good.
Partly the same topic…today I tried to add a Shelly Uni to my Homey Pro but failed.
The icon seems wrong and maybe mixed up with the similar product named “Shelly Add-On”?
Are both these devices supposed to work?
Thanks!!
@Henning
You’d better look in the Shelly topic
Hi guys,
Does anyone have problem logging in to shelly integrator portal (shelly 1 device) using the link in the image posted by Dijker?
I’m using homey bridge and homey test app version 6.9.1.818 on an IOS device.
Simply i use credentials (correct ones) and tap on “login” but nothing happens. Wifi is working properly, homey and iphone have been rebooted but nothing improved.
It seems to me to be a “internal browser issue” in the homey app but i don’t have a different device where to test it.
Any suggestions would be appreciated
Cheers
Francesco
Have you tried copying the link by long pressing it and pasting it in a separate browser?
Yes but i can’t copy the link. When i try long pressing it opens anyway into shelly internal browser. (i double checked right now)
Try pairing it trough a browser using the Athom developer tools: Homey Developer Tools
Thank you!
Using the dev tool i was able to copy and paste the link and all went well.
Thanks again!
Hey Peter,
I was using the app on ios and i hadn’t similar sharing options.
Anyway i solved with the Phuturist solution.
Thanks
Ah I see, Francesco! But it is solved now and that’s
Hi
I have a Homey cloud gateway. My question if the shelly bluetooth door/window senor will be compatable with my Homey?
Welcome, Johannes.
Homey Cloud instance can only connect to other supported cloud devices. Most, if not all, Shelly wifi enabled devices are.
Homey Cloud + a Homey Bridge can connect to certain Shelly devices, like zigbee & z-wave, but not Bluetooth versions.
You can discover this @ homey.app store:
https://homey.app/a/cloud.shelly/
Make sure the Homey selector is set to [Homey Cloud] (in pink)
Then you’ll see the Homey Cloud supported devices. Wifi versions ( == “any Shelly cloud connected device”) don’t need Homey Bridge btw.
Idea:
Now Shelly sells a Bluetooth gateway, to connect Shelly Bluetooth device to wifi and “the cloud”.
This would mean (to me): you can add this gateway to Homey Cloud, and have the Bluetooth sensors available for Homey Cloud.
Knowing our highly appreciated Herr Uwe @Undertaker owns Shelly Bluetooth devices and Shelly Bluetooth gateway(s), maybe he is willing to comment on:
do Bluetooth sensors become available to Shelly Cloud by pairing them with the Shelly Bluetooth gateway?
Thanks in advance!
Hi
Thank you for an great answer
I have sent Mr Uwe a message if they can add functionality for the Shelly Bluetooth gateway and the ble Door/window sensor that would be much appreciated. Because my aeotec sensors don’t seems to function
Best regards Johannes
