Hello, I have 2 homey bridge and one homey pro at home.
Everything has worked without problems so far. I had the Homey bridge set in satellite mode. One day the electricity in our house went out because of a storm. And since then I can’t add homey bridge even one to homey pro. Homey pro finds them for me, I go through adding them to Homey pro. I find the network, give the password, everything works, the ring on the HB starts flashing green and then turns blue, and after a while I get the error Error checking status. I don’t know how to add them so they can connect again and be online. Have you encountered this problem?
I would suggest Athom support:
For support or issue resolution, first have a look at support.athom.com. If you are unable to find the answer to your question on support.athom.com you can send a support request to Athom via https://support.athom.com/hc/requests/new.
If you need help you can read more about how to submit a support request.
When filing a support request, make sure you add all necessary information so Athom can help you as quickly as possible.
