Homey-api Typings are not working with local API
Hey,
I’d like to build a next.js App as a local Dashboard for my Raspberry. For this, I’d like to use the Web API of the Homey Pro (early 2023).
I was hoping for some typings and found the homey-api package on npm. I’ve set up my api client like this:
However, everything I do get from calling this function is a Promise with any as a generic Type. This is pretty useless in my opinion, as IntelliSense won’t be of much help. Using any is never good.
Am I missing something or are there simply no typings for a local connection? I’d rather not implement my own Typings…
Nico
Homey’s typings aren’t very well maintained.
Thanks. I already thought that this would be the problem. Are there any community-projects maintaining those?
Not that I’m aware of, no.
Check how HomeyScript does it?
Because in it, intellisence works pretty okay i would say, beter then nothing.
I actually just extended the API types as it seems that all those “Manager”-Classes are actually just props on the API client object.
This should be done by Athom in the first place (as it’s easier to maintain types when you control the sources) but if it helps someone, here’s the homey-api.d.ts file I’m now using:
import { HomeyAPIV3Local } from 'homey-api';
declare module 'homey-api' {
  export class HomeyAPIV3LocalPatched extends HomeyAPIV3Local {
    manager: HomeyAPIV3Local.Manager;
    alarms: HomeyAPIV3Local.ManagerAlarms;
    api: HomeyAPIV3Local.ManagerApi;
    apps: HomeyAPIV3Local.ManagerApps;
    arp: HomeyAPIV3Local.ManagerArp;
    ble: HomeyAPIV3Local.ManagerBLE;
    backup: HomeyAPIV3Local.ManagerBackup;
    clock: HomeyAPIV3Local.ManagerClock;
    cloud: HomeyAPIV3Local.ManagerCloud;
    coprocessor: HomeyAPIV3Local.ManagerCoprocessor;
    cron: HomeyAPIV3Local.ManagerCron;
    database: HomeyAPIV3Local.ManagerDatabase;
    devices: HomeyAPIV3Local.ManagerDevices;
    devkit: HomeyAPIV3Local.ManagerDevkit;
    discovery: HomeyAPIV3Local.ManagerDiscovery;
    drivers: HomeyAPIV3Local.ManagerDrivers;
    energy: HomeyAPIV3Local.ManagerEnergy;
    experiments: HomeyAPIV3Local.ManagerExperiments;
    flow: HomeyAPIV3Local.ManagerFlow;
    flowToken: HomeyAPIV3Local.ManagerFlowToken;
    geolocation: HomeyAPIV3Local.ManagerGeolocation;
    googleAssistant: HomeyAPIV3Local.ManagerGoogleAssistant;
    i18n: HomeyAPIV3Local.ManagerI18n;
    icons: HomeyAPIV3Local.ManagerIcons;
    images: HomeyAPIV3Local.ManagerImages;
    insights: HomeyAPIV3Local.ManagerInsights;
    ledring: HomeyAPIV3Local.ManagerLedring;
    logic: HomeyAPIV3Local.ManagerLogic;
    matter: HomeyAPIV3Local.ManagerMatter;
    mobile: HomeyAPIV3Local.ManagerMobile;
    notifications: HomeyAPIV3Local.ManagerNotifications;
    presence: HomeyAPIV3Local.ManagerPresence;
    rf: HomeyAPIV3Local.ManagerRF;
    safety: HomeyAPIV3Local.ManagerSafety;
    satellites: HomeyAPIV3Local.ManagerSatellites;
    security: HomeyAPIV3Local.ManagerSecurity;
    sessions: HomeyAPIV3Local.ManagerSessions;
    system: HomeyAPIV3Local.ManagerSystem;
    thread: HomeyAPIV3Local.ManagerThread;
    update: HomeyAPIV3Local.ManagerUpdates;
    users: HomeyAPIV3Local.ManagerUsers;
    virtualDevice: HomeyAPIV3Local.ManagerVirtualDevice;
    weather: HomeyAPIV3Local.ManagerWeather;
    webserver: HomeyAPIV3Local.ManagerWebserver;
    zigbee: HomeyAPIV3Local.ManagerZigbee;
    zones: HomeyAPIV3Local.ManagerZones;
    zwave: HomeyAPIV3Local.ManagerZwave
Then use it with:
import { HomeyAPIV3, HomeyAPIV3LocalPatched } from 'homey-api';
const homeyApi = await HomeyAPIV3.createLocalAPI({
    address: 'http://ip-address',
    token: 'token',
    debug: null,
}) as HomeyAPIV3LocalPatched;
And don’t forget to include your homey-api.d.ts file in your tsconfig.json.
This seems to work pretty well though I haven’t checked all “Managers” for their functionality (just created these props according to the web api reference).
Homeyscript doesn’t use Typescript but Javascript, so it’s weakly typed and doesn’t have to deal with return types, etc.
Indeed, i totally agree that its weak. However, much beter than absolutely nothing :wink:
Note that using TypeScript definitions this way will greatly limit your access to the data returned by the Homey API, since it doesn’t declare the properties of objects returned by the API.
For example, this is the all the data returned for a Ring Floodlight device:
"095ff1bd-b969-462d-a0df-01ee4f04f4fa": {
    "id": "095ff1bd-b969-462d-a0df-01ee4f04f4fa",
    "uri": "homey:device:095ff1bd-b969-462d-a0df-01ee4f04f4fa",
    "driverId": "homey:app:com.amazon.ring:stickupcam",
    "ownerUri": "homey:app:com.amazon.ring",
    "name": "Hugo",
    "note": null,
    "zone": "5204dc44-8e9c-49e7-aed8-9d5c93330126",
    "data": {
      "id": 128842480
    "icon": null,
    "iconOverride": "camera",
    "iconObj": {
      "id": "a5ba9ca3e23e89dbbd327bb20dbcb32f",
      "url": "/api/icon/b271a6a6-afd3-4534-9982-c989e58aab34"
    "class": "sensor",
    "virtualClass": null,
    "capabilities": [
      "alarm_generic",
      "alarm_motion",
      "flood_light",
      "siren"
    "capabilitiesObj": {
      "alarm_generic": {
        "id": "alarm_generic",
        "type": "boolean",
        "iconObj": null,
        "title": "Generic alarm",
        "getable": true,
        "setable": false,
        "insights": true,
        "insightsTitleTrue": "Generic alarm turned on",
        "insightsTitleFalse": "Generic alarm turned off",
        "value": false,
        "lastUpdated": "2023-03-27T17:43:47.453Z"
      "alarm_motion": {
        "id": "alarm_motion",
        "type": "boolean",
        "iconObj": null,
        "title": "Motion alarm",
        "getable": true,
        "setable": false,
        "insights": true,
        "insightsTitleTrue": "Motion alarm turned on",
        "insightsTitleFalse": "Motion alarm turned off",
        "value": false,
        "lastUpdated": "2024-08-14T12:32:43.653Z"
      "flood_light": {
        "id": "flood_light",
        "type": "boolean",
        "iconObj": null,
        "title": "Flood light",
        "getable": true,
        "setable": true,
        "insightsTitleTrue": null,
        "insightsTitleFalse": null,
        "value": false,
        "lastUpdated": "2024-08-27T20:47:55.264Z"
      "siren": {
        "id": "siren",
        "type": "boolean",
        "iconObj": null,
        "title": "Siren",
        "getable": true,
        "setable": true,
        "value": false,
        "lastUpdated": "2023-03-27T17:43:47.442Z"
    "settings": {
      "zone_activity_disabled": false,
      "useMotionDetection": true,
      "motionTimeout": 30,
      "subscribeMotionDetection": true,
      "useMotionAlerts": true,
      "energy_value_constant": null
    "settingsObj": true,
    "flags": [],
    "energy": null,
    "energyObj": {
      "W": null,
      "batteries": [
        "INTERNAL"
      "cumulative": null,
      "generator": null,
      "approximated": null
    "ui": {
      "quickAction": "flood_light",
      "components": [
          "id": "toggle",
          "capabilities": [
            "flood_light",
            "siren"
          "id": "sensor",
          "capabilities": [
            "alarm_generic",
            "alarm_motion"
      "componentsStartAt": 1
    "uiIndicator": null,
    "available": true,
    "unavailableMessage": null,
    "warningMessage": null,
    "ready": true,
    "repair": true,
    "unpair": false,
    "images": [
        "type": "camera",
        "id": "Hugo",
        "title": "snapshot",
        "imageObj": {
          "id": "47c25d42-3978-435b-92f0-b124589388be",
          "url": "/api/image/47c25d42-3978-435b-92f0-b124589388be",
          "lastUpdated": 1724121489567
    "color": "#1A98D5"
As you can see, this is way more than what is described in the documentation and thus in the TypeScript definitions…
