Homey 2.0.0 Experimental discussion [EN]
Does anybody know if the Candy app is working on Homey 2.0.0?
I thought I had read somewhere that the app is not working, but I can’t find it anywhere now.
Thanks!
**Apologies if there is another thread for the new app (testflight)
I’m having issues where the testflight app (IOS) 0.17.0.234 crashes when I try to configure the advanced settings of my zwave devices (Aeotec and Fibaro dimmers, aeotec sensor 6)
e.g advanced settings to set the ‘switch type’ or change the ‘motion delay reset’
Any guidance?
Anyone got geofence working on Sony Xperia Z1?
I read at slack that they already know the problem with crashing when changing z-wave settings and they will fix it soon as possible.
Ok thanks, good to know
hello, I still can not update to rc 3. I’ve tried it 10 times. homey crashes
Ronny i had the same problem after soms resets from it started the upload
Hi All, another query from me.
Homey v2.0rc3
App 0.17.0.234
Sonos (beta) v4.0.17
When adding a “play a spotify track” on a Play5 , the flow provides a ‘red’ exclamation mark and gives an XML error. 500 …<UPnPError …s:Client
does the same with just a ‘play’ call from Homey to Sonos
any suggestions/pointers please.
NOTE - let me know if this needs to go in an “apps for 2.0/0.17.0.234” thread.
Andrew
Hallo, my Homey is dead. Red ring and can not the reset the little orb. What to do plz?
@Koen_Fehrmann Pull the plug for 10 minutes and reinsert the plug and then wait for at least 10 minutes.
Unfortunately, no success, I have only a second user and have deleted this. I can’t still update rc 3. I regret the update to v 2.0. it is a very bad beta.
Did not work, still red ring
@Koen_Fehrmann You better contact support
I read you have a red ring after you PTP? I assume that your device first seems to start normal (yellow ring circling) and then a solid red ring? And a factory reset is not possible to activate by having the device upside down (after 30-sec)? Then you should contact Athom support.
I had the same issues and my device needed to be flashed again by Athom.
Thank you Casper, just how you discribed. I will send the Homey team a mesage.
I’m still on 1.5.13 so the situation might not be 100% the same, but I’ve been having a red ring problem for over a year now.
At every reboot I have a red ring. It always takes me several attempts, but after a while I always manage to boot Homey correctly.
So I would advise you to first try several PTP’s with a lot of time in between.
I mostly give up after 2, 3 times, pull the plug and go to bed. In the morning it boots again…
If you send it to Athom, they will probably flash and erase it and you’ll have to start from 0, pairing devices and making flows again…
You can switch to version 231, that’s the latest version without that issue.
I’m curious. Does the 2.0 app work without an active internet connection?
(Can I use the app if my internet connection is down and my phone is on the same wifi network as the Homey sphere)
Homey v2.0.0-rc.4 is now available…
Homey v2.0.0-rc.4:
  • [Core] Added socket.showView(), socket.nextView(), socket.prevView() and socket.done() to onPair()
  • [Core] Fixed Device.setSettings()
  • [Core] Fixed a bug where devices could not start a Flow
  • [Core] Fixed athom app run --clean
  • [Core] Various improvements
FYI
https://firmware.athom.com/
