Hello everyone, I’m trying to connect my Hikvision recorder to Homey Pro using Onvif. Onvif recognizes the recorder and the 6 channels I’m using. However, when I add the channels, I see the same image on each channel. How can I adjust this? And is live streaming possible as well? I would prefer to have a few live images on the dashboard…
Please use the Onvif app topic, to reach the developer, thx.
Links to that topic are mentioned at the app store app page.
Try coping the snapshot url and paste it into the user snapshot url, then change the 101 to 102 to sae if that helps.
Tried it but unfortunately doesnt work…
Could you open the app settings page and select the Diagnostics Log tab, set the Log level to Detailed and then restart the app. Go back to the Diagnostics Log and once it has captured the details, tap on Send Log.
The log is huge and i can’t fit it all in this box, but here is a part:
Log ID: 2025-04-20T07:24:00.907Z
App version 2.0.48
7:24:0.907: Initialising CameraDevice (192.168.2.9 (Ch1))
7:24:0.915: Initialising CameraDevice (192.168.2.9 (Ch2))
7:24:0.917: Initialising CameraDevice (192.168.2.9 (Ch3))
7:24:0.921: Initialising CameraDevice (192.168.2.9 (Ch4))
7:24:0.924: Initialising CameraDevice (192.168.2.9 (Ch5))
7:24:0.927: Initialising CameraDevice (192.168.2.9 (Ch6))
7:24:10.614: --------------------------
7:24:10.617: Connect to Camera 192.168.2.9:91 - admin
7:24:10.733: getSystemDateAndTime (192.168.2.9): Sun Apr 20 2025 08:23:43 GMT+0000 (Coordinated Universal Time), Time Shift: 3572268 Finished -----
7:24:10.737: getServices (192.168.2.9): Started *****
7:24:10.798: getServices (192.168.2.9): Finished -----
7:24:10.801: getCapabilities (192.168.2.9): Started *****
7:24:10.851: getCapabilities (192.168.2.9): Finished -----
7:24:10.998: VideoSources (192.168.2.9): [
"token": "VideoSourceToken001"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"colorSaturation": 50,
"contrast": 55
"token": "VideoSourceToken002"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 55
"token": "VideoSourceToken003"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"token": "VideoSourceToken005"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"token": "VideoSourceToken006"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"token": "VideoSourceToken008"
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
7:24:11.002: getActiveSources (192.168.2.9): Unrecognized configuration form [
"token": "ProfileToken001",
"fixed": true
"name": "ProfileName001",
"videoSourceConfiguration": {
"token": "VideoSourceConfigurationToken001"
"name": "VideoSourceConfigurationName001",
"useCount": 2,
"sourceToken": "VideoSourceToken001",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"audioSourceConfiguration": {
"token": "AudioSourceConfigurationToken001"
"name": "AudioSourceConfigurationName001",
"useCount": 2,
"sourceToken": "AudioSourceToken001"
"audioEncoderConfiguration": {
"token": "AudioEncoderConfigurationToken001"
"name": "AudioEncoderConfigurationName001",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"IPv4Address": "0.0.0.0"
"port": 8862,
"TTL": 128,
"autoStart": false
"sessionTimeout": "PT30S"
"PTZConfiguration": {
"token": "PTZConfigurationToken001"
"name": "PTZConfigurationName001",
"useCount": 0,
"nodeToken": "PTZNodeToken001",
"defaultContinuousPanTiltVelocitySpace": "http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace",
"defaultContinuousZoomVelocitySpace": "http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace",
"defaultPTZTimeout": "PT60S"
"extension": {
"audioOutputConfiguration": {
"token": "AudioOutputConfigurationToken"
"name": "AudioOutputConfigurationName",
"useCount": 2,
"outputToken": "AudioOutputToken",
"sendPrimacy": "www.onvif.org/ver20/HalfDuplex/Server",
"outputLevel": 10
"audioDecoderConfiguration": {
"token": "AudioDecoderConfigToken"
"name": "AudioDecoderConfig",
"useCount": 2
"token": "ProfileToken002",
"fixed": true
"name": "ProfileName002",
"token": "VideoSourceConfigurationToken002"
"name": "VideoSourceConfigurationName002",
"useCount": 2,
"sourceToken": "VideoSourceToken002",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"token": "AudioSourceConfigurationToken002"
"name": "AudioSourceConfigurationName002",
"useCount": 2,
"sourceToken": "AudioSourceToken002"
"token": "AudioEncoderConfigurationToken002"
"name": "AudioEncoderConfigurationName002",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken003",
"fixed": true
"name": "ProfileName003",
"token": "VideoSourceConfigurationToken003"
"name": "VideoSourceConfigurationName003",
"useCount": 2,
"sourceToken": "VideoSourceToken003",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"token": "AudioSourceConfigurationToken003"
"name": "AudioSourceConfigurationName003",
"useCount": 2,
"sourceToken": "AudioSourceToken003"
"token": "AudioEncoderConfigurationToken003"
"name": "AudioEncoderConfigurationName003",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken005",
"fixed": true
"name": "ProfileName005",
"token": "VideoSourceConfigurationToken005"
"name": "VideoSourceConfigurationName005",
"useCount": 2,
"sourceToken": "VideoSourceToken005",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"token": "AudioSourceConfigurationToken005"
"name": "AudioSourceConfigurationName005",
"useCount": 2,
"sourceToken": "AudioSourceToken005"
"token": "AudioEncoderConfigurationToken005"
"name": "AudioEncoderConfigurationName005",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken006",
"fixed": true
"name": "ProfileName006",
"token": "VideoSourceConfigurationToken006"
"name": "VideoSourceConfigurationName006",
"useCount": 2,
"sourceToken": "VideoSourceToken006",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"token": "AudioSourceConfigurationToken006"
"name": "AudioSourceConfigurationName006",
"useCount": 2,
"sourceToken": "AudioSourceToken006"
"token": "AudioEncoderConfigurationToken006"
"name": "AudioEncoderConfigurationName006",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken008",
"fixed": true
"name": "ProfileName008",
"token": "VideoSourceConfigurationToken008"
"name": "VideoSourceConfigurationName008",
"useCount": 2,
"sourceToken": "VideoSourceToken008",
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"token": "AudioSourceConfigurationToken008"
"name": "AudioSourceConfigurationName008",
"useCount": 2,
"sourceToken": "AudioSourceToken008"
"token": "AudioEncoderConfigurationToken008"
"name": "AudioEncoderConfigurationName008",
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken009",
"fixed": true
"name": "ProfileName009",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"useCount": 0,
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken010",
"fixed": true
"name": "ProfileName010",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken011",
"fixed": true
"name": "ProfileName011",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken013",
"fixed": true
"name": "ProfileName013",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken014",
"fixed": true
"name": "ProfileName014",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
"token": "ProfileToken016",
"fixed": true
"name": "ProfileName016",
"useCount": 2,
"bounds": {
"x": 0,
"y": 0,
"width": 1280,
"height": 720
"useCount": 2,
"useCount": 2,
"encoding": "G711",
"bitrate": 64,
"sampleRate": 8,
"multicast": {
"address": {
"type": "IPv4",
"port": 8862,
"TTL": 128,
"autoStart": false
"extension": {
"useCount": 2,
"outputLevel": 10
"useCount": 2
7:24:11.008: Error getting video sources: Unrecognized configuration
7:24:11.013: setActiveSource (192.168.2.9): Invalid source for this device
7:24:11.034: ** service capabilities 192.168.2.9 (Ch1) = {
"network": {
"IPFilter": false,
"ZeroConfiguration": false,
"IPVersion6": true,
"DynDNS": true,
"Dot11Configuration": false,
"Dot1XConfigurations": 0,
"HostnameFromDHCP": false,
"NTP": 1,
"DHCPv6": false
"security": {
"TLS1.0": false,
"TLS1.1": false,
"TLS1.2": false,
"OnboardKeyGeneration": false,
"AccessPolicyConfig": false,
"DefaultAccessPolicy": false,
"Dot1X": false,
"RemoteUserHandling": false,
"X.509Token": false,
"SAMLToken": false,
"KerberosToken": false,
"UsernameToken": true,
"HttpDigest": true,
"RELToken": true,
"MaxUsers": 32
"system": {
"DiscoveryResolve": false,
"DiscoveryBye": true,
"RemoteDiscovery": false,
"SystemBackup": false,
"SystemLogging": false,
"FirmwareUpgrade": false,
"HttpFirmwareUpgrade": true,
"HttpSystemBackup": false,
"HttpSystemLogging": false,
"HttpSupportInformation": false
7:24:11.039: getServices (192.168.2.9): Started *****
7:24:11.068: getServices (192.168.2.9): Finished -----
7:24:11.072: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/device/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/device_service",
"capabilities": {
"capabilities": {
"network": {
"IPFilter": false,
"IPVersion6": true,
"DynDNS": true,
"NTP": 1,
"DHCPv6": false
"security": {
"TLS1.0": false,
"TLS1.1": false,
"TLS1.2": false,
"Dot1X": false,
"SAMLToken": false,
"HttpDigest": true,
"RELToken": true,
"MaxUsers": 32
"system": {
"version": {
"major": 2,
"minor": 10
7:24:11.077: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/media/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/media_service",
"capabilities": {
"capabilities": {
"SnapshotUri": true,
"Rotation": false
"profileCapabilities": {
"MaximumNumberOfProfiles": 17
"streamingCapabilities": {
"RTPMulticast": false,
"RTP_TCP": false,
"RTP_RTSP_TCP": true,
"NonAggregateControl": false
"version": {
"major": 2,
"minor": 10
7:24:11.082: ** Snapshots are supported on 192.168.2.9 (Ch1)
7:24:11.088: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/events/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/event_service",
"capabilities": {
"capabilities": {
"WSSubscriptionPolicySupport": true,
"WSPullPointSupport": true,
"WSPausableSubscriptionManagerInterfaceSupport": false,
"MaxNotificationProducers": 10,
"MaxPullPoints": 10
"version": {
"major": 2,
"minor": 10
7:24:11.091: ** PushEvent supported on 192.168.2.9 (Ch1)
7:24:11.095: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver20/ptz/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/ptz_service",
"capabilities": {
"capabilities": {
"EFlip": false,
"Reverse": false
"version": {
"major": 2,
"minor": 10
7:24:11.098: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver20/imaging/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/imaging_service",
"capabilities": {
"capabilities": {
"ImageStabilization": false
"version": {
"major": 2,
"minor": 10
7:24:11.102: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/deviceIO/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/deviceio_service",
"capabilities": {
"capabilities": {
"VideoSources": 6,
"VideoOutputs": 2,
"AudioSources": 6,
"AudioOutputs": 1,
"RelayOutputs": 1,
"SerialPorts": 0,
"DigitalInputs": 4
"version": {
"major": 2,
"minor": 10
7:24:11.107: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/recording/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/recording_service",
"capabilities": {
"capabilities": {
"DynamicRecordings": false,
"DynamicTracks": false,
"Encoding": "H264 G726",
"MaxRate": 16384,
"MaxTotalRate": 16384,
"MaxRecordings": 8,
"MaxRecordingJobs": 6,
"Option": true
"version": {
"major": 2,
"minor": 20
7:24:11.110: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/search/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/search_service",
"capabilities": {
"capabilities": {
"MetadataSearch": false,
"GeneralStartEvents": false
"version": {
"major": 2,
"minor": 20
7:24:11.118: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/replay/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/replay_service",
"capabilities": {
"capabilities": {
"ReversePlayback": false,
"SessionTimeoutRange": "5 30",
"version": {
"major": 2,
"minor": 20
7:24:11.124: ** Service 192.168.2.9 (Ch1){
"namespace": "http://www.onvif.org/ver10/receiver/wsdl",
"XAddr": "http://192.168.2.9:91/onvif/receiver_service",
"capabilities": {
"capabilities": {
"RTP_Multicast": true,
"RTP_TCP": false,
"SupportedReceivers": 8,
"MaximumRTSPURILength": 255
"version": {
"major": 2,
"minor": 20
7:24:11.145: Camera Information (192.168.2.9 (Ch1)): {
"manufacturer": "Hangzhou Hikvision Digital Technology Co., Ltd",
"model": "DS-7608NI-K2%2F8P",
"firmwareVersion": "V4.30.071, build 210517",
"serialNumber": "0820210805CCRRG47736832WCVU",
"hardwareId": 255
7:24:11.150: getCapabilities (192.168.2.9): Started *****
7:24:11.179: getCapabilities (192.168.2.9): Finished -----
7:24:11.185: Camera (192.168.2.9 (Ch1)) supports PullPoint
7:24:11.222: Supported Events(192.168.2.9 (Ch1)): JOBSTATE,RECORDINGJOBCONFIGURATION,RECORDINGCONFIGURATION,TRACKCONFIGURATION,MOTION,TAMPER,DIGITALINPUT
7:24:11.261: setActiveSource (192.168.2.9): Invalid source for this device
7:24:11.294: Snapshot URL: http://192.168.2.9:91/onvif/snapshot/101
7:24:11.310: Registering Now image (192.168.2.9 (Ch1))
7:24:11.315: registered Now image (192.168.2.9 (Ch1))
7:24:11.322: SnapShot save file (192.168.2.9 (Ch1)) = eventimageurn_uuid_34d2788d_8129_466d_adb7_aff03412b7a7__ch1_.jpg
7:24:11.327: Registering event image (192.168.2.9 (Ch1))
7:24:11.353: registered event image (192.168.2.9 (Ch1))
7:24:11.360: Camera (192.168.2.9 (Ch1)) is ready
7:24:11.365: --------------------------
7:24:11.370: Connect to Camera 192.168.2.9:91 - admin
7:24:11.387: getSystemDateAndTime (192.168.2.9): Sun Apr 20 2025 08:23:44 GMT+0000 (Coordinated Universal Time), Time Shift: 3572614 Finished -----
7:24:11.392: getServices (192.168.2.9): Started *****
7:24:11.420: getServices (192.168.2.9): Finished -----
7:24:11.424: getCapabilities (192.168.2.9): Started *****
7:24:11.449: getCapabilities (192.168.2.9): Finished -----
7:24:11.524: VideoSources (192.168.2.9): [
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 55
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 55
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
"framerate": 25,
"resolution": {
"width": 1280,
"height": 720
"imaging": {
"brightness": 50,
"contrast": 50
7:24:11.528: getActiveSources (192.168.2.9): Unrecognized configuration form [
"fixed": true
"useCount": 2,
"sourceToken":
Please use pre-formatted text in future so that other users can see easily that this is code, a device interview, protocols, etc. So everything that you haven’t typed in yourself, except for quotations.
These pre-formatted texts can also be copied for other users with just a single click, which reduces the workload for other users, especially for the app developers.
@Jeroen_Coenradi Edited for you
It appears that your NVR isn’t returning any videoEncoderConfiguration sections in the profiles, which is preventing the app from selecting a source and then fetching the correct snapshot URL.
I’m not sure if the app actually needs that information, as it doesn’t provide a live stream, so I might be able to change the library to cope.
In the meantime, all I can suggest is to try variations of the last number to see if you can fine the required snapshot URL. Tray variations of 102, 201, 202, etc.
You are the best!!! the variations of 201/301/401/etc works!!! now i can finally watch the camera’s. Thank u so much.
One more question… is it possible to have live screens instead of snapshots?
No, Homey doesn’t support live streaming. Maybe in the future as it’s been rumoured the HP2023 might.
ok, final question (sorry) is there a possibility to automatically update the snapshot in my dashboard? say every 10 seconds?
You should be able to do that via a Flow.
