Hello, I have installed the heos app for my marantz AV. Everything works fine except the power button in the app. When I press I get a error. It is very strange because all the other functions work.
When i press on the ‘receiver icon’ in my device tab, the AV Will turn on and off. So its only the button in the app that is not working.
The on off button is the exact same button as pressing the device tile (device tile is even called “quick action”, as it makes you quickly use the on/off button).
Clicking the tile button start playing the HEOS speaker/AVR, so technically not turn it on, so it can be anything that is wrong.
But you aren’t telling a lot of information, what Homey, what Homey version, what app version, what is the error (without the telling the error it is saying your car doesn’t drive, and you came on your bicycle to the car shop).
This is the extra information: homey pro 2023 version 11.0.0. App version: 8.1.2.1471. Here i have two Av’s, brand: marantz type cinema 50 and the sr 7012.
When installing it true homey it found the receivers directly. Everything works. Only the on and off button in the app is not responding.
When I push it in the left upper corner the red message comes: “not connected!”. The receivers both didnt react on that command. All the rest in the apps both the receivers response perfecly.
I have the same problem with my Marantz Cinema 40. It’s rather annoying because then you can’t use receiver status or power control in flows. But a little workaround is to add the receiver as an IR device also, then you can power on and off via infrared, but that shouldn’t be necessary.
Same as described. Cannot turn on or off the Denons (x3800h and 1600avrs). Now setting them to pause instead, hope they will go off themselves after inactivity.
I now use a spotify card putting them on play with a flow…
Thanks Brian! Using NR1510 and this workaround (although a bit janky) works perfectly! Infrared for power off, HEOS app for the rest, Spotify Connect app if you want to power it on using Spotify songs/playlists etc
A year late to the party but I have the same issue of the HEOS Homey app not turning on/off my Denon X1700H. I’ve en using the Denon AVR app for power control, but since recently (don’t know when) that app does not work at all anymore with my Denon.
i’ll try the IR thing later but I suspect that wont work on account of the denon being behind a door. Just posting here in case someone has found another way
