Hello I wonder if anyone here has any suggestions on this I have a pump that I want to monitor, if the pump has not drawn any power for xx number of hours, I would like to receive an alarm about this. I have a device that registers when it turns on and starts I hope you understand what I mean
Thanks for the answer but I don’t have that option in my sensor which is a “Shelly PM mini 16 A smart power meter” and to clarify my question it is a drain pump that starts with a level gauge in the pump. and if the pump has not been running for xx hours, I would like to be alerted to it in some way
Is there a homey app that supports the shelly pm 16?
Yes Shelly app does it, I have four Shelly PM mini 16 smart power meters in my system
Can’t it read the power?
Then its’s simpel.
Make a timer (countdown app)
start the timer with 43600 (4hours) Depends on the time you want to check)
every time power is up → stop timer → restart the timer with 43600 sec
If timer is empty → Give a warning
