Weslop
August 2, 2019, 6:08pm
1
Hello all,
I would like to trigger a flow with an http request card.
I use the following address for this:
https://myathomcloudid.connect.athom.com/api/manager/logic/webhook/Toezichtuit
When I respond to the request in my internet browser, it says “ok”
Only the flow is not started.
If I test the flow, it just works.
What am i missing here?
Thanks for the responses.
Greeting Weslop
Can u also try this without the capital T at Toezichtuit?
Weslop
August 3, 2019, 6:07am
3
Even with a small t the flow does not start.
Can u show screenshots from ur flows?
And to check, did you replace ‘myathomcloudid’ with your own cloud id?
Ok, just to be sure
I’m very interested in your flow(s) then, because it should work.
When I made my first requests, the widget app on my phone automatically used http instead of https, which didn’t work, but I’m guessing you got that covered as well.
First card should be “toezichtuit” is ontvangen.
Plz try without capital letters.
Weslop
August 3, 2019, 6:50am
10
copy pasted the link from the card, so should be okay.
I’m probably doing something wrong somewhere
The first thing ur doin wrong is explained in the post above urs.
Jup, what @Rocodamelshekima posted is the solution.
You don’t require the entire link in the logic-card, just the last word (toezichuit)
Edit: Good to hear, enjoy!
Just to make sure for future reference:
U NEED to only fill in the event in that card, in this case “toezichtuit”. It’s a must!
