Hi everyone,
I’m looking for advice on how to integrate my iiglo Motorized TV Lift Stand (model TVL1002) into my smart home setup. The lift is controlled via an RF remote (model RMT-02), which operates on the 2.437 GHz frequency (FCC ID: 2AG62RMT-02).
I initially purchased a BroadLink RM4 Pro, but unfortunately, it only supports 315/433 MHz frequencies and is unable to learn or transmit signals at 2.4 GHz. My goal is to control the lift using Amazon Alexa or Homey, but I’m struggling to find an RF blaster that supports this specific frequency.
I’ve considered a few alternative solutions, such as:
Using an IR-based workaround: Checking if the TV lift has any hidden IR control options (though none are mentioned in the manual).
Preloaded code databases: Investigating if there are any universal RF controllers that might have a preloaded code compatible with the lift.
My last resort would be to 3D print a custom case that holds my remote control and two SwitchBot Bots to physically press the buttons, but I’d rather avoid that if possible.
If anyone has experience with RF solutions in the 2.4 GHz range, or has successfully integrated a similar device, I’d greatly appreciate your advice!
Thanks in advance.
