Heimdall - Let Homey watch over your home
Sorry, I was away for a few days. i just turned the delay function on. I’m going to test it this weekend.
Hi Jakob. Do you have any suggestions on how to set up this flow if there are two windows/doors open so that it works with the speaker? When I have one door open, it works for my Google speaker, but when there are two #warnings, it is silent. Notification to the timeline works with 2 warnings, but not saying it out in the speaker.
Hello. I would like to start a flow when a curtain person has enabled or disabled the alarm. I see that it is writen in the heimdall logging, but i can’t start there a flow with.
Is it possible to include this feature in heimdall?
Thanks.
This has been discussed before, as soon as Athom adds functionality that exposes which user performed a action on a device like selecting a status I will add such a flow card.
So -please- raise this request at Athom!
Perfect. That would be great. I will request homey, @DaneedeKruyff. But it is also not possible by the heimdall logging? I made many users in the heimdall app that can enable or disable the heimdall alarm, but are not part of the homey users.
  1. I don’t want everybode to be able to turn off or on device’s by giving everybody access by a homey app.
  2. People like my mother don’t want to install another app from what they don’t understand how it works.
I bought a frient keypad that for them is easy to use. Place a NFC card or token and enable or disable the alarm. And i would love to see which user enabled or disabled the heimdall alarm.
Is this request really only possible by athom homey?
The thing is, right now a user is only known when an external keypad is used, Ring, Frient but only a small percentage of Heimdall users use a keypad, so for most this flowcard with a user tag would simply not work, resulting in lot’s off support requests why the tag doesn’t work.
As said, it’s been discussed before in this topic, I understand it’s a lot of posts, but all information can be found in this topic.
Thank you. I will search thru this forum.
I made the request by athom homey. I let you @DaneedeKruyff know if i get a response.
Hello @DaneedeKruyff.
I contacted Athom for the problem of distinguish of users in the heimdall app. I told them there is a problem to see which user activated or deactivted the alarm while in survaliance security mode of homey. They said they couldn’t help me. Only by request of the developer of the heimdall app.
This is there email:
May 2, 2025, 10:43 GMT+2
Hi Pieter,
Bedankt voor jouw reactie en feedback en correct uitleg. Dat kan ik wel waarderen.
Het is goed dat je eerst contact hierover hebt gelegd met de Community ontwikkelaar, Danee de Kruyff, maar dit gaat dan buiten ons (daarmee bedoel ik onze supportteam) om.
De Community ontwikkelaar, in dit geval dus Danee de Kruyff heeft al blijkbaar zelf rechtstreeks contact met onze ontwikkelaars hierover.
Dat is ook de te volgens procedure. Ik heb hierover zelf ook net contact gehad met onze ontwikkelaars. Aanpassingen / requests zullen door een Community app ontwikkelaar zelf gemeld moeten worden bij onze ontwikkelaars.
Dan is het afwachten tot het is aangepast of dat Dannee nogmaals een melding stuurt naar onze ontwikkelaars hierover om dit issue nogmaals onder de aandacht te brengen.
Ik kan hier verder ook niets mee, hoe vervelend ik dat ook vind. Ik ben net zoals jij (helaas) afhankelijk van anderen, daarom sluit ik dan ook dit ticket
Hoop op je begrip hiervoor.
Met vriendelijke groet,"
Did you already approached Athom?
Sorry, i hope i don’t request to much. I love the Heimdall app. But if this request is implanted i will give this app a 10+
Typical.
I’ve been in contact with Athom about this, directly with Emile, he couldn’t give me an eta, and told me it isn’t a priority. I can’t give it a higher priority, I had the hope if user would express their desire for this Athom would act upon it, but clearly I was wrong. :confused:
Sadly it is. I think this request went only to customer service, and stayed there. We did our best. There is nothing more we can do. For now thanks for the great app.
Ja jammer ik mis deze functie ook. Maar zo moeilijk moet het niet zijn. Heimdall heeft zijn eigen users, met daaraan een pin en/of een RFID tag. Heimdall logging weet welke user een pin of RFID heeft aangegeven.
Zou niet moeilijk moeten zijn om de Users uit de heimdall log te koppelen (via een flow) aan Homey. Andere Apps doen dit ook (Unifi bevoorbeeld).
Alle gegevens zijn voorhanden in de heimdall app. Lijkt mij zeer essensieel om te weten welke gebruiker iets met je alarm gedaan heeft. Maakt dus ook niet uit of je een keypad (Fiend koppeld direct op heimdall) od een rfid lezer gebruikt.
I was hoping for that too. That the user who enabled or disabled the alarm could retrieve it from the Heimdall logging. However, @DaneedeKruyff indicated that it caused many errors and was therefore not possible, unfortunately. Hopefully, he still manages to get it to work. It would be very helpful for me to know who disabled my home alarm, as I could do that with the Ring keypad. Especially since I switched to Frient keypad RFID, which does not transmit that information when used with Heimdall and not locally.
Please translate your post, this is an English topic
If you know it so well ;). Then program and share it :wink:
Hi everybody,
I’ve got a problem with frient keypad and heimdall.
I can activate easily full alarm or partial alarm.
My problem is when full mode is activated. I remove the main door of the alarm but I have fibaro motion sensor which is detected me. Even if I desactivate alarm during the tempo (20sec) I have to do twice : first one stop the “future” alarm and second desactivate alarm monitoring.
I don’t understand because it’s the way if the alarm is triggered after tempo, but before it’s unlogical.
Thanks a lot.
Ced.
I can’t really understand what your’re doing, could you please explain in different words what you mean with
Also, the next part, I guess the tempo you mention is the Alarm Delay, when all is configured according to the instructions in this topic all you would have to do when the Alarm Delay is active is to switch the Surveillance Mode to Disarmed
Do you have flows configured on top of the actions your keypad takes, if so, could you please post some screenshots of them here?
Thanks for your answer. So I’ll rewrite my question.
When the surveillance mode is activated, if someone is detected (motion sensor or door/window opened), I have to do twice on frient keyboard to disarm : first one is stopping the alarm during the delay so the alarm doesn’t ring and second one to switch off the surveillance mode.
If I do only once, the surveillance mode is reactivated like before the detection.
Thanks.
And what do you ‘do’ on the Frient keypad?
Do you have any flows configured?
Have you checked the log in Heimdall settings?
If use a badge or keycode and press unlock but I’ll to do twice.
For frient keypad : no flow.
For Heimdall : only a notification when surveillance is on and alarm is “ringing”.
It looks like the delay doen’st care.
Yes I add to this message (sorry I’m french).
