Can you try to disconnect and reconnect power to the Z-TRM3 as additional step and report results?
Tried to power cycle twice. Unfortunately no change.
Exclusion and inclusion with very close proximity helped in my case.
@Hakon_Vinge Could you share a screenshot of the ID’s mentioned in the Advanced settings of the basic Z-wave device?
Yes, thanks.
Are you sure that it is a Heatit branded device you’re trying to add to Homey?
The manufacturer ID points towards FutureHome AS…
Then I would contact Heatit (I’ll make a report as well); apparently something went wrong with the firmware programming.
Thanks a lot. Just to clear out. I have tried four different items. They all give the same result.
Likely this is batch (FW programming) related. I’ve already send a message to my contacts at Heatit to inform them and point to your messages / pictures.
Any updates on this Ted? Thanx.
I would recommend that you contact Heatit support (or the reseller) directly to get this resolved.
I have the the Heatit z-trm3, and have been using if togheter with homey for a few months. I started getting some issues with the heating switching from active to idle every few minutes, so I tried resetting the thermostat and reconnecting it to Homey. Now I have the issue that the Thermostat does not actully switch on when I increase the set temperature above the current temperature.
Example: Measure temperature is 22.0. I set thermostat to 23 using buttons on the heat-it, and it turns on fine. I reduce the temperature to 20 using ahtom and it turns off. But if I increase the temperature using Athom til 23 the displayed temperature on the thermostat changes (after a 10 second delay that was not there before), but the thermostat does not actually switch on. If I then go in and change the temperature using the buttons on the thermostat it switches on.
Any advice is much appreciated
I added the z-trm3 a couple of monts agom but then it started working. I removed it from homey, and did a factory reset in the cintrol unit. And now, i cant add it again. From the inclusion-instructions it lokes more like im trying to remove it, and also the unit only shows “Err” when i try to add it.
What can i do?
Never mind, it seemed to work now
Hi, I have an issues with connecting a new Z-Push Button 8. After following the procedure it starts connecting, and following message appears: “No compatible Homey App has been found for this device. It has been added as a Basic Z-Wave device”. Installers manual is dated 01.10.2019 Verson 2019-B. Both Homey and Heatit device is brand new. Any suggestions?
Edit: I have tried to uninstall / install the app on Homey. Factory reset of the Heatit device did not help either.
Edit: I have found my device is having same issue as @Hakon_Vinge is having with his 4 channel push button. Screenshot below. From what I have understood the devic supports over the air (OTA) firmware upgrade. Anyone know if new firmware is available and how to initiate it? @TedTolboom, apprechiate if you can share how to proceed with this issue. Do I have to return the devices to the vendor?
Image of the back side of my Z-Push Button
Did you set the advanced associations correctly?
something with Group 1 on 1.1, (its mentioned in this topic somewhere)
