Heatit z-trm2fx thermostat is spamming network
Hi.
I have adjusted parameters on all my devices to reduce z-wave traffic because of the error with "too much traffic.
I can see that my z-trm2fx thermostat is spamming the network with meter reports, even if reporting is set to 600seconds. It seems like when the thermostat is idle, the reports it sent every 10 minutes now, but when heating is on, then the thermostat spams with reports.
Does anyone have a soloution to this?
I have attached the log
[2023-09-19T07:26:24.350Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:24.409Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,122,72]},"Meter Value":{"type":"Buffer","data":[0,1,122,72]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:24.487Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,116]},"Meter Value":{"type":"Buffer","data":[9,116]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:40.350Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:40.409Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,121,61]},"Meter Value":{"type":"Buffer","data":[0,1,121,61]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:40.489Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,115]},"Meter Value":{"type":"Buffer","data":[9,115]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:56.351Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:56.410Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,122,4]},"Meter Value":{"type":"Buffer","data":[0,1,122,4]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:26:56.490Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,115]},"Meter Value":{"type":"Buffer","data":[9,115]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:27:12.354Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:27:12.411Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,121,101]},"Meter Value":{"type":"Buffer","data":[0,1,121,101]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:27:12.491Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,116]},"Meter Value":{"type":"Buffer","data":[9,116]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:00.362Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:00.420Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,120,126]},"Meter Value":{"type":"Buffer","data":[0,1,120,126]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:00.499Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,115]},"Meter Value":{"type":"Buffer","data":[9,115]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:16.363Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:16.422Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,119,200]},"Meter Value":{"type":"Buffer","data":[0,1,119,200]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:16.502Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,113]},"Meter Value":{"type":"Buffer","data":[9,113]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:32.365Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:32.422Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,119,89]},"Meter Value":{"type":"Buffer","data":[0,1,119,89]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:32.501Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,109]},"Meter Value":{"type":"Buffer","data":[9,109]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.367Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,21]},"Meter Value":{"type":"Buffer","data":[0,1,109,21]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.423Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.503Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.578Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.676Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.705Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.734Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.835Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.895Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:48.955Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.113Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.194Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.223Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.363Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.753Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.770Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:49.943Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:50.021Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:50.109Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:50.222Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,110]},"Meter Value":{"type":"Buffer","data":[9,110]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.369Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[36]},"Properties2":{"Size":4,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,109,22]},"Meter Value":{"type":"Buffer","data":[0,1,109,22]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.413Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.482Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.580Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.642Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.709Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.807Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.899Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:56.971Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.073Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.133Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.176Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.336Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[84]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":2},"Meter Value (Raw)":{"type":"Buffer","data":[0,1,118,135]},"Meter Value":{"type":"Buffer","data":[0,1,118,135]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.479Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,106]},"Meter Value":{"type":"Buffer","data":[9,106]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
[2023-09-19T07:28:57.566Z] Node[4]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[161]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":true},"Properties2 (Raw)":{"type":"Buffer","data":[34]},"Properties2":{"Size":2,"Scale bits 10":0,"Precision":1},"Meter Value (Raw)":{"type":"Buffer","data":[9,106]},"Meter Value":{"type":"Buffer","data":[9,106]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0}
Please use search and ask in the appropriate topic, as linked in the App store or use the search to centralize questions about a specific App of device/brand:
[APP][Pro] Heatit Controls app [v3.6.2]
Therefore this thread has been moved in the appropriate topic.
If you have any problems with that please feel free to contact me or another moderator.
