Flow Variables
Part of: H.O.O.P. (Hope) - Homey Object Oriented Programming
Summary
This device offers flow condition cards to handle variables synchronised within the flow.
It allows for expressions with methods you can create yourself in the settings.
The expression gets sandboxed in a VM with all options of the V8 Javascript Engine.
So you can use Math.floor and a lott more!
This is very handy for working with arrays, and you want to fiddle with it.
Setting vairable type to Json makes sure you can use quote’s within array’s without messing it up later when retrieving it.
Variables are put down as flowtokens. If you use these flowcards within flows triggered by H.O.O.P., the variables are scoped(!) so simultaneous execution is possible within H.O.O.P.
Conditions
- Set [[type]] [[name]] to [[expression]]
This conditioncard lets you create and set a variable instantly with a expression.
Settings
Functions
random Function
Examples
Example Array
Example Number
