Guide for dummies - Send IR signals with Homey Pro 2016-2019
I recently worked out how to control infrared devices by sending IR signals with Homey, so here’s a guide so you can do the same. It is way more complicated than it should be (if you have the old, white ball version of Homey), but at least there is a way. You need to create an app, set up flow cards and IR signals, and install it to your Homey. The steps are detailed below.
If you have a newer Homey Pro (flat black thingy), there should be flow cards available to send IR signals out of the box. Recording IR signals is not possible, though.
The guide is written for Windows computers, but should work much the same for Mac and Linux as well.
Step 0: Check if IR device already exist in Homey
  1. Before going through all the work of creating you own app, check if the device already exist in Homey’s library. In the Homey App, go to
       Device → New Device → Infrared
and search for your brand name. The search algorithm is wonky, so make sure you type the entire name. “Opto” gives 0 results, “Optoma” gives plenty.
Step 1: Get the IR signal
Option A: You have a remote (or something that sends the IR signal)
  1. Download and install IR Scrutinizer ( IrScrutinizer – AppImages )
  2. Head over to https://tools.developer.homey.app/ (and make sure you’re log in) and scroll down until you find “RF” in the left hand side menu.
  3. In the dropdown meny next to the record button, select “Infrared”
  4. Click the red record button
  5. Click the button on your remote (or whatever is sending the IR signal), while pointing it towards Homey
  6. The signal should appear as a bunch of comma separated numbers
    (If this isn’t working, try turning off the led ring on your Homey and repeat)
  7. Copy the numbers and open IR Scrutinizer
  8. Click “Paste & Scr.”
  9. You should now see a bunch of numbers and letters in groups of four. Copy these and store them somewhere (for instance in notepad).
  10. Repeat for all other IR signals
Option B: You don’t have anything that sends this IR signal
Check out this database of IR codes ( GitHub - probonopd/irdb: One of the largest crowd-sourced, manufacturer-independent databases of infrared remote control codes on the web, and aspiring to become the most comprehensive and most accurate one ), or try searching online for your device, along with “ir prontohex” and see if anything shows up.
Step 2: Test the signal
  1. Go back to https://tools.developer.homey.app/ and this time go to “Infrared” in the left side menu.
  2. Paste the prontohex code you got from IR Scrutinizer or from the web, and enter “1” in the “Repetitions” box
  3. Click send and verify that your device responded. If not, the device might be out of range or there’s something wrong with the prontohex signal.
  4. Hopefully, you now have a list of all the IR signals you want and have checked that they work!
Step 3: Become a developer
  1. Download Node.js to your computer and install ( Node.js — Download Node.js® )
  2. Open command prompt and enter the following command: npm install -g homey
  3. After it’s installed enter this command: homey login
  4. Log in with your Homey account and click allow
Done!
(If you stuggle, check out the official video from Homey: https://www.youtube.com/watch?v=v_RUamZzby8)
Step 4: Create the app
  1. In Command Propt, enter the following command: cd Desktop
  2. Next, enter this command: homey app create
  3. Give your app a name and description
  4. Give your app an ID (The convention is to use the reverse of a domain name, but I think anything goes)
  5. Select a category, and then hit Enter until you see green text saying your app is installing
  6. Next, enter this command: cd *app ID*
    (replace *app ID* with the ID you gave your app just moments ago)
Well done!
Step 5: Create the flow cards
For each signal, we need a flow card.
  1. In Command Prompt, enter the following: homey app flow create
  2. Select “Action (then)”
  3. Give it a title and an ID (the title and ID should reflect a specific ir signal, for instance “Turn on receiver”)
  4. Hit enter to skip the hint
  5. Type No when asked about arguments
  6. Click enter to create the flow card
  7. Repeat this step for each of your signals
(Note: There is likely a way to add a dropdown argument so that only one action card is needed, and the argument refers to the IR signal you want to send. This task is left as an exercise to the reader (but do let me know if you work out how))
Step 6: Edit the app
Note: You can do all the editing in Notepad, as described in the steps, but using a software that understands code (notepad++, visual studio code, etc. will make it much easier to spot typing errors).
6.1 Create permission for infrared
  1. Click Win + E (open file explorer) and navigate to your app. It should be under C:\Users\*username*\*app ID*
  2. First, open the .homeycompose folder and find “app.json” (Note: this is different from the app.json in the main folder! Make sure you are looking in the .homeycompose folder)
  3. Right click the file and select “edit in notepad”
  4. Find “permissions”: [ ] and enter “homey:wireless:ir” (With the quotation marks) inside the square brackets. It should now look like
     “permissions”: [“homey:wireless:ir”],
  5. Save and close the file
6.2 Create signal file
  1. Open notepad and hit Ctrl + n (new document).
  2. Enter the following:
“type”: “prontohex”,
“cmds”: {
"*signal 1*": "*prontohex code*",
"*signal 2*": "*prontohex code*"
  1. Replace *signal x* with a name for each signal and *prontohex code* with the corresponding code from Step 2.
    NB! Make sure there is a comma after each prontohex (after the quotation mark), except for the last one.
  2. Click File → Save As, and navigate to C:\Users\*username*\*app ID*\.homeycompose\signals\ir
  3. Change the name to “my_signal.json” and change the “Save as type” to “All files”
6.3 Edit the app.js file
  1. Go back to file explorer and navigate to the main app folder (C:\Users\*username*\*app ID*)
  2. Right click app.js and open in notepad (Note: we want app.js, NOT app.json)
  3. Find “this.log(“My app has been initialized”);
  4. Place your cursor right behind the semi colon and hit enter to create a new line.
  5. Paste the following text:
    const mySignal = this.homey.rf.getSignalInfrared(“my_signal”)
  6. Hit enter again to insert a new line, and paste the following command:
     const *some name* = this.homey.flow.getActionCard(“*flow card ID*”);
  7. Change *some name* into some name for this card (without spaces or special characters) and change *flow card ID* to the actual ID of one of your flow cards.
    (For instance: const cardTV = this.homey.flow.getActionCard(“watch-tv”):wink:
  8. Copy and paste the line, one for each flow card you’ve made, and change the name and ID correspondingly. (Make sure to hit enter each time so that they don’t appear right after each other on the same line)
    (If you don’t remember the ID of your flow cards, look in C:\*users*\*app ID*\.homeycompose\flow\actions. The ID of the flow card is the same as the file name.)
  9. Next, paste this chunk of code right below:
    *some name*.registerRunListener(async () => {
    await mySignal.cmd(“*IR signal name*”)
  10. Change *some name* into the one of names you used above, and *IR signal name* to the corresponding name used for the signal in Step 6.2
  11. Copy and paste this chunck, once for each signal, and change the *some name* and *IR signal name* for each
    (If you are confused at any point, compare your code to mine: GitHub - jonsoln/com.jb.IR: Homey IR App )
DONE! Your app should be ready now!
Step 7: Test the app
  1. In Command Prompt, type: homey app run
  2. The app should hopefully initialize correctly without errors
  3. Now, go to your Homey app on your phone, or to my.homey.app
  4. Go to Flow → New Flow
  5. Add a When-card, choose Flow → This Flow is started
  6. Click Done
  7. Add a Then-card, scroll down to apps and choose your app
  8. Select one of the flow cards
  9. Click Done
  10. Click the play button to test your flow.
  11. Check that your IR device responded as expected.
Great success!
Step 8: Install the app
  1. In command prompt, hit CTRL + C to abort the testing
  2. Type the following command: homey app install
You did it! Now you can create flows to send IR signals.
Appendix
Shout out to Jamie ( Creating an Infrared (IR) device ) for making a guide that got me thinking “I can do this!”
Thank you and Interesting …. What are differences / limitation for using a similar method for the Homey Pro 2023 ?
Thank you
For Homey Pro 2023, you should be able to send infrared signals without having to create your own app. You might have to enable the Power User Experiment.
However, the 2023 version lacks an infrared receiver, so it cannot learn signals from a remote. You have to find the signals online, or use another device than can read infrared signals.
Hi Jon, too bad it can’t receive but good to know. Thank you!
