Hi all,
I bought a Qazqa uplight from LampenLicht, which unfortunately does not remember it’s status when the outlet is turned off via a relais. This means, we have to either physically turn on the light, or use the remote control.
The remote control sends a IR-signal, which via developer.athom.com I was able to read out in the following command:
9079,4471,602,1641,610,525,616,521,611,541,600,523,608,531,610,539
614,524,605,1649,596,527,614,1640,612,1637,654,1600,600,1650,616,1634,605,1682,568,528,613,527,605,1646,607,526,614,526,603,539,608,540,604,520
613,1637,617,1641,605,525,617,1638,602,1656,595,1647,607,1640,608,1639
611,39923,9071,2214
615,65535
I remember from trying to get this working a few months ago, that with software called GTKWave I have to translate/compile the above code. I’m retrying now, but am a little lost again, but I am sure I will manage to do that again.
Within Homey - a few months ago - I was able to paste code in Homey Developer Tools which enabled me to turn the light on/off via the browser.
Next step I would like to achieve, is to be able to use this in a flow, as simple as possible. All I need to do is turn the light on or off.
Is it possible to copy a very simple code and put that in a flow? Or do I really have to go through the trouble of creating an app, which as a non-programmer I will not be able to do.
Many thanks in advance for your help!
