[APP][Pro] Deluxe Homeart - Your ambiance, your control! 🕯️📲
Deluxe Homeart
Easily control your Deluxe Homeart LED candles with Homey! This app uses IR signals to turn your candles on and off and adjust various settings. Thanks to the integration with Homey, you can automate your candles and link them to flows for the perfect ambiance at home.
:sparkles: Features:
:white_check_mark: IR control for Deluxe Homeart LED candles
:white_check_mark: Create flows to automatically turn candles on or off
:white_check_mark: Set timers for 2, 4, 6, or 8 hours
Create a warm and cozy atmosphere with Homey and your favorite Deluxe Homeart candles! :candle:
The app uses IR signals to mimic the remote control commands of Deluxe Homeart LED candles.
Make sure your Homey is placed near the candles, the candles are visible to Homey, and the Homey IR transmitter is not obstructed.
:small_blue_diamond: Have LED candles from another brand and want to use them with Homey? Send me a message, and I’ll see if I can add support for them!
Links:
Install app here
First of all fanatic work with this app!
I am using the app, but when I click ‘on’ it also turns on but immediately turns off again.
When I click ‘off’ it turns off but immediately comes back on and stays on.
It seems like it sometimes gets multiple signals because it flickers when turned on or off.
Thanks for your feedback and for using the app!
The flickering you’re seeing happens because the candles briefly respond when they receive an IR command. This is normal behavior and confirms that the signal was received.
To improve reliability, the app currently sends each command multiple times (up to 3 times) with a small delay in between. This ensures that if the first signal should not arrive correctly, a backup signal is sent. However, if multiple commands (on/off/timer) are triggered in quick succession, the candles may receive overlapping signals, causing them to turn on and off unexpectedly.
I recommend waiting a few seconds before sending a new command to allow the previous command (including all IR signals) to fully complete.
I’m considering adding an option for users to adjust the number of times a command is sent. This would give you more control over the IR signal behavior and help fine-tune it to your setup.
Would you be interested? Let me know, and thanks again for your support!
Ah thanks for the explanation.
It would be a nice addition if you could set that. If there is anything I can test, please let me know :+1:t3:
Test version
Great to hear! I’ve now built and implemented the option to adjust both the number of times a command is sent and the delay between commands. This should give you more control over how the IR signals are handled and help fine-tune the behavior for your setup.
Would you be able to test it and let me know if it improves the experience for you?
Yes! This works perfectly for me. For my situation, one command works best!
Thanks!
I have a 2019 pro and this Homey sends a apparently week IR-signal.
I tested the candles with this set up and not all the candles switch on or off:
Could you try adjusting the ‘send command’ setting in the device settings? This allows the device to automatically send multiple commands per button click, so you can choose how many times the IR signal is transmitted. Sometimes, sending the signal a few more times helps ensure all devices turn on or off correctly.
Let me know!
Tried that already. Didn’t help.
I think the app is ok. The IR-signal is to poor.
I’m sorry my app can’t help you. Maybe you could try a broadlink device or something.
App is nice, but what about the situation, when you have 2 Homeys (1 Pro and 1 Bridge) in different rooms (living room and bedroom) as well as candles. There is no chance to add a new device to control the candle in the living room and the candle in the bedroom. All that I can do is adding one device and after that change the antenna in the settings. I hope I am not mistaken. Can this be solved somehow ?
Thanks for your feedback.
Hi @Leon_Oosterhuis , thanks for this app. So funny to see there’s an app for these candle lights too :).
I bought 2 candles a few months ago and both could be controlled correctly. Since this week I notice 1 of them cannot be controlled. I also only see 1 device (candle light) in stead of 2. Deleting this device and adding again didn’t work to get both working. Changing with fresh new batteries did not change either.
Any chance why? Is there some opportunity to reset the candle so Homey can detect it again?
Hi Osado,
It works with infrared. It’s more like you ad the remote control as a device and that has a candle icon. When you press the digital button the Homey sends out 1 infrared code signal which will turn all the candles of this brand on. If it doesn’t work for a candle with fresh batteries there are 3 possibilities:
  1. There is something standing in between the candel and the Homey that blocks the infrared signal.
  2. The candle is from another brand.
  3. The candle is broken.
I think the problem is in this setup. Infrared must be able to reach each candle directly, in a straight line. The candles in the front are probably blocking the signal for some off the candles the back…
Hi Leon,
Great app. Thank you.
Our Deluxe Homeart candles can also be dimmed with the remote control. Is it possible to add that to the app?
And, maybe I’m asking to much, but for the candle tile in the app: now you can press it and then the candles turn on. But when you press it again nothing happens . For lights for example: when you press it they turn on and a yellow dot apperas. When you press it again it turns off and the yellow dot goes away. Is this possible for the candles as well?
Deluxe Homeart v3.1.0
This update adds new brightness controls and improves Flow support.
New in this release
  • ‘+’ and ‘-’ buttons to increase or decrease candle brightness
  • New settings for brightness command repeat count and delay
  • New device Flow cards for on, off, timer, brightness up, and brightness down
Flow changes
  • The old app-level Flow cards are still supported for existing Flows
  • These old cards are now marked as deprecated
  • New Flows should use the new device Flow cards instead, since they are linked directly to a selected candle device
Other improvements
  • Multiple identical candle devices can now be added
  • Existing devices are automatically updated with newly added capabilities
Existing Flows will continue to work, but going forward the new device-based Flow cards are the recommended setup.
