Gradual Light Alarm with iPhone
Hi all,
I’ve been trying to create a flow and system that would gradually turn on my lights with my alarm, but I’m having trouble fitting all the moving pieces together with Flows as it seems like Homey Pro is missing some critical pieces to make it work.
  1. iOS Shortcut to set alarm
  • To set an alarm, start the shortcut and it will set the alarm on the iPhone and send a web hook with the alarm time for tomorrow
  1. Flow to store the alarm
  • Accept the web hook
  • Store the datetime in a variable
  • PROBLEM 1: How would a tag from a web hook be converted into a valid datetime object usable to trigger a flow? Variables doesn’t seem to be supporting a date time object
  • PROBLEM 2: I need to make sure that only one value is always stored as my alarm; There needs to be a way to calculate 30 min before the alarm and calculate the variable to include tomorrow’s date.
  1. Start a flow 30 min before alarm
  • Dynamically start a flow with the datetime that computes 30 min before the alarm
  • Turn on the lights by increasing relative dim-level by 10% every couple of minutes
  • PROBLEM 3: I did not find a way to dynamically start a flow based on a dynamically changing time. The only thing I found was Auto Scheduler, but that requires setting a permanent time per day of week that is not easily changeable via a flow.
  1. Flow that delete the alarm if I should remove it
  • Another flow should delete the alarm if a new web hook comes in with that information from iOS.
Maybe someone attempted this previously and has a couple of pointers? Would be amazing to rebuild this! Thank you!
I don’t have all the answers.
But for your inspiration: The standard Homey ‘Alarms’ has trigger-cards ‘one hour before alarm goes off’ etc. I want to leave for work at 8:10. So I set an alarm in homey at 8:10.
One hour before the alarm goes off the heating turns on and a wakeup light dims from 0 to 100% during 15 minutes.
45 minutes before homey beeps (homey pro 2019) and iI get up. My status is changed to ‘awake’ so lights go on.
5 min before i get a reminder.
1 min for another reminder to put my coat on. My status is changed to ‘away’. Radio turns off. Lights go out slowly so I don’t have to move aroud in the dark.
Thank you Wim! I tried using that functionality but there was no way to set it via a flow - from what I understand is that the alarm can only be set via HomeyScript. I also can’t find conclusive documentation from Athom on this topic. Do you know? :blush:
I don’t have any problems with enabling an alarm and adjusting the time in homey but I understand that is a no-go for you.
Have you checked the Timey app?
I have not yet, thanks for linking me! Looks promising indeed!
Hi Wim, Timey indeed did the trick - I got it working! Thanks a lot for the help. :blush:
I’m currently stuck on the same task. Would you be so kind as to describe your solution in a little more detail here? …that would be great!
Hi @quellenform , sure - I ended up implementing a system that communicates from Shortcuts to Homey via Webhooks. Attached, the images of the flows I’m using to store and trigger the alarms for the next day. Let me know if you have any specific questions!
Cool, thanks for sharing this workflow!..but I would replace the picture with your Homey ID if I were you :wink:
Is the card “Dim to x% during x minutes” specific to your device? …I can’t see that with my light bulbs.
Good shout, thank you!
It comes with the Philips Hue integration, I didn’t have this option with other lightbulbs. Maybe you’re not using Hue’s? :blush:
Yes, I use Hue lights, but this one feature seems to be specific to a wakeup light (Twilight?). I don’t see this option with the normal Hue lights, and in that case you would have to program your own fade-in.
Ah, in that case a right-click on the ‘THEN’ action should do it like pictured here:
